cbr1000rr5 erratic starting/immobiliser prob - Honda Motorcycles - FireBlades.org
post #1 of 9 Old 08-31-2013, 5:55 PM Thread Starter
hello all hope one of you can help I bought a 2005 fireblade from Sheldon mcs last nov love the bike but had probs galore!!!
1st>datatool alarm draining battery and hard to start like immobilised removed alarm
2nd>battery much better now no alarm bike turns over much quicker but still erratic problem starting bike hot or cold clocks rev counter does full cycle but without the fuelpump/injectors noise? bike turns over and over but wont start very hit and miss it did it last week when warm popped in shop came out no sound when ignition switched on when bike does pre starting clock display checks? messed for a while flicking stand up and down turning key on and off kill switch on and off nothing? had a fag turned the key boom! clock check sound fired up first thumb!!?? ok all week to and from work the odd spin out no probs today started fine went work came home leathers on went a blast out called in at my cousins there four about an hour turned the key no pre start sound the rev counter did full cycle but no sound again three hours messing as before nothing parked there still could this be an hiss/imobiliser prob?
any help much appreciated regards mark
allycatdoody is offline
post #2 of 9 Old 09-01-2013, 2:18 AM
Quoted: 128 Post(s)
Reputation Power: 66
Re: cbr1000rr5 erratic starting/immobiliser prob
Sounds like the kill switch to me. As long as the headlights come on, your clocks run through their normal pre-checks, and it tries to crank this usually indicates either the fuel pump starting to fail or the kill switch going bad. Try to by-pass the kill switch by hooking the two wires for it together and give her a go. If that does not fix the problem start looking at all your grounds, and do a wire check of the pump wires. Also run though ALL of your fuses and your fuel pump relay. Try this stuff out and let us know the outcome. I put my money on the kill switch for anyone keeping score =P
RRDemon is offline
post #3 of 9 Old 09-01-2013, 2:19 AM
Quoted: 128 Post(s)
Also, not sure if you have done this or not; Try to make your way over to the introductions section and post up a brief bio and some bike pics! Some of us (mainly me) love some bike porn!!! I think this is an outstanding site with a lot of helpful people, certainly worth hanging around for a while!
RRDemon is offline
post #4 of 9 Old 09-01-2013, 8:45 AM Thread Starter
hey many thanks for input rrdemon very much appreciated will check all of the above and again cheers bud your a star I will let ya know
post #5 of 9 Old 09-01-2013, 11:05 PM
Quoted: 128 Post(s)
I would start with the kill switch as they tend to intermittently fault for a while before they die off completely. Keep us up to date!
RRDemon is offline
post #6 of 9 Old 09-02-2013, 4:09 AM Thread Starter
cheers mate my friend whos a sparky is goin to check the bike over when he gets time in the week I gave him your input and he agrees totally with what you said once again thanks for your valuble input I will let you know the outcome asap
regards mark
post #7 of 9 Old 09-02-2013, 9:47 AM
Reputation Power: 113
Either killswitch or the HISS acting up. Does the yellow light go out on the dash?
Sky91 is offline
post #8 of 9 Old 09-02-2013, 3:22 PM Thread Starter
hey sorry for slow reply the bikes at my cousins he checked and no orange hiss light comes on at all
regards mark
post #9 of 9 Old 09-09-2013, 5:11 AM Thread Starter
well cheers to all who said it was the kill switch
spot on bike running fine again cheers people
regards mark
'99 immobiliser problem? Nickydeep Honda FireBlade 15 01-08-2013 8:18 AM
99 fireblade immobiliser problems Nickydeep General Discussion 1 01-06-2013 6:39 PM
CBR1000RR5 EXHAUST GASKET? MADBIKER1981 Honda FireBlade 1 04-04-2012 11:15 AM
96 900rr erratic idle 96FIREBLADE900R Honda FireBlade 2 06-28-2008 11:40 AM
cbr1000rr5 bbr-streetgang Honda FireBlade 3 07-24-2006 2:37 PM
