Clunking in 1st with clutch in - Honda Motorcycles - FireBlades.org
post #1 of 5 Old 09-05-2013, 3:04 PM Thread Starter
Need some insight please.
The RRP has started to clunk - the same kind of clunk you get when you've lost the gear youre in while changing with the clutch in so you release it a bit and 'clunk'. However this clunk happens now when I'm in first with the clutch held in. Happens about a second apart about 4-5 times. I release the clutch and it pulls away fine. If i stop, change back to first, hold clutch in same thing happens. Not all the time tho, mainly when engine is hot.
Additional notes: i have a Barnett clutch. Engine was very low on oil recently not sure if it coincides. Changing down from second through neutral to first has always been a bit crunchy on this bike. Clutch rattles a bit. I've just had new tyres fitted/chain adjusted too.
Any ideas what this could be? TIA.
BaNJaX is offline
post #2 of 5 Old 09-05-2013, 3:19 PM Thread Starter
Re: Clunking in 1st with clutch in
ok think chain is too tight. Just noticed hardly any play in it and the chain is clicking on front sprocket when i pull clutch in. Sound right
BaNJaX is offline
post #3 of 5 Old 09-05-2013, 3:56 PM
Pmb
Reputation Power: 11
My 97 RRV clunks into first with the clutch in and makes the usual rumble with the clutch out. I don't think any of the Hondas I've owned have been particularly smooth or slick selecting first gear.
Pmb is offline
post #4 of 5 Old 09-05-2013, 5:52 PM Thread Starter
Thanks. Had the back wheel out looks like it might be sprocket/cush drive alignment. Going to take it to a mates garage tomorrow.
BaNJaX is offline
post #5 of 5 Old 09-14-2013, 6:10 AM Thread Starter
I took the plates out and the inner ones were completely dry and 'stuck' against each other. The beveled edges of the plates were a little worn and where they sit in the basked it also showing signs of wear. All I can think is the plates aren't moving freely. I rubbed down the edges of each to make sure they are smooth and covered them in oil when I put them back in. Seemed ok for a bit but its started doing it again today.Do you think it's worth soaking the plates in oil? Might be related to the fact I had very low oil for a few weeks?
BaNJaX is offline
Clunking noise in 2nd and 3rd gear Raymondpalm13 Honda FireBlade 0 05-22-2012 2:34 PM
CLUNKING sound when throttling off or on... chipcollector Honda FireBlade 6 07-07-2008 5:33 AM
Clunking first gear??? Ninja95 General Discussion 50 03-14-2008 2:39 AM
clunking gearbox. Baz1966 Honda FireBlade 12 06-15-2007 4:48 PM
clunking when shifting from 1st to 2nd? BadBrad Honda Naked Sportbikes 9 01-13-2007 12:52 PM
