Bike died while running, fuel pump wont prime - Honda Motorcycles - FireBlades.org
post #1 of 14 Old 10-04-2013, 1:23 AM Thread Starter
Reputation Power: 11
So my bike is currently sitting in a parking lot because I have no way of getting it home tonight which really sucks. A few weeks ago once in a great while when I turned on the run switch I wouldnt hear the fuel pump priming noise, but the bike would start. I even turned the bike off and restarted the process and the fuel pump would prime no problem. This happened a few times. Then recently I noticed my gas light is very unreliable. Sometimes it would have no gas and the light wouldnt come on until the last minute, or the light woudl come on around the mileage it normally does, but quickly go off and not come back on until the tank was near empty again.
So tonight I go to the store, come out and the bike starts up fine (been driving all week including today). Then maybe 100 feet later the bike just stalls out and dies while I was moving. After that I could no longer get the bike to start back up. I even tried to push start it multiple times (no luck). The fuel pump would not prime again after MANY attempts. As I was pulling into the store I did notice the bike started to get a little choppy, I thought maybe I was low on gas again because I was past the normal mileage the light comes on, but could still hear gas in the tank. I had the wife bring me gas just to make sure that wasnt the case also.
I am thinking about jsut pulling the trigger on a new fuel pump, but would hate to waste the money. Are there any quick checks I can do before that this weekend. The problem is I am in school and this semester is literally taking up all my time studying and doing homework, so I dont have much time to trouble shoot. I also cant afford to shotgun too many parts that are not bad.
01 929
socci is offline
post #2 of 14 Old 10-04-2013, 1:33 AM
Quoted: 129 Post(s)
Reputation Power: 66
Re: Bike died while running, fuel pump wont prime
I would start by checking all fuses and the grounding blocks throughout the entire bike. There are many times with the 929s and 954s that a suspected electrical problem or bad part was nothing more than a corroded ground. That would be the logical first step, best part of it- it's free to do, just takes some time to dig to all the grounds! Get that done first, if you still have no luck we'll go from there.
RRDemon is offline
post #3 of 14 Old 10-04-2013, 2:57 AM
Quoted: 120 Post(s)
Reputation Power: 198
There's a bunch of other thing it could be besides the fuel pump. I'd try some other things first.
Check your main 30 amp fuse.
Could be a relay going out too. The ones to check are your fuel pump relay and your bank angle relay. You can swap your high beam relay into them to test. I'd do the fuel pump relay first, turn the key and listen. If nothing, swap it with the bank angle relay and try again.
Then, as stated above start checking connections, like battery posts, grounds, fuel pump connector...
jondog9 is offline
post #4 of 14 Old 10-04-2013, 5:33 AM
Did you lose the dash lights when she died?
Don't use the kill switch, use the ignition switch to shut the engine off. If you still had dash lights I'd be looking at the kill switch.
The pump doesn't need to prime if you just turned the engine off and the fuel rail is still pressurised.
It's a waste of time trying to bump start the bike if the injectors aren't pressurised.
The fuel sender and the fuel pump are two different things, a problem with the sender is unlikely to be related to the pump.
post #5 of 14 Old 10-04-2013, 2:25 PM Thread Starter
Thats what I was afraid of. Sounds time consuming.
Will do, so lets say I get nothing when I swap with the the pump relay, when I swap with the bank angle sensor, if I get something does that means the bank angle sensor was bad obviously right?
The pump doesn't need to prime if you just turned the engine off and the fuel rail is still pressurised. It's a waste of time trying to bump start the bike if the injectors aren't pressurised. The fuel sender and the fuel pump are two different things, a problem with the sender is unlikely to be related to the pump.
No I had all the dash lights. I was just reading using the kill switch is bad, I never knew that. I have been using the switch all season. How do I go about testing the switch?
01 929
socci is offline
post #6 of 14 Old 10-04-2013, 2:27 PM
Push a pin through the two wires to bypass the switch and see if the problem persists.
post #7 of 14 Old 10-04-2013, 10:01 PM Thread Starter
So lets say this works and my kill switch is bad, could I cut the switch and just wire the two wires together until I find a replacement unit? I havent had much luck finding a better way to bypass the switch, and I really would hate to have to put the bike away for the remainder of the season even if it is short lived. I figure I can def find a new switch over the winter.
01 929
socci is offline
post #8 of 14 Old 10-04-2013, 11:20 PM
Quoted: 120 Post(s)
In a word - yes.
Go do it and let us know if that gets you going again.
jondog9 is offline
post #9 of 14 Old 10-05-2013, 5:26 AM
Quoted: 129 Post(s)
Wiring up a new kill switch is as easy as adding a toggle switch =P It is really just there in case of emergency such as stuck wide-open throttle. This gives you a way to cut the fuel supply to the engine therefore making it stop.
My buddy wired an additional hidden kill switch that worked as a theft deterrent too. He had the normal switch in place as well, but ended up replacing it with a different (much cheaper) radio-shack switch after his died. I think it cost him $6 for both switches that he put in...
RRDemon is offline
post #10 of 14 Old 10-07-2013, 12:56 AM Thread Starter
So I went to look at the kill switch wiring and found a one of the two metal plugs detached. I plug the little metal tab back into the male end and figured that had to be the problem. Im not exactly sure which wires are for the kill switch I assumed it was them. There is also a wire bundle wrapped coming from the same area along with another wrapped up thin wire bundle. I cant see the wires in them, not sure what they go to. But attaching that loose wire did not fix the problem, I thought for sure it was. Are those two wires with the metal tabs the kill switch wires?
01 929
socci is offline
post #11 of 14 Old 10-07-2013, 1:03 PM
Quoted: 120 Post(s)
What color are they?
Bladeracer posted wiring diagrams for the 954.
https://www.fireblades.org/forums/hon...-diagrams.html
jondog9 is offline
post #12 of 14 Old 10-07-2013, 4:29 PM
Reputation Power: 8
my 954 was doing this to me at one point. Tore open the earth block (yellow box) behind the headlight and cleaned it out. It was burnt a little but put it back together and electrical taped it and now it hasn't done it since.
Honda is probably all I know! 2005 Civic Si, 2002 CBR 954!
Bryan1444 is offline
post #13 of 14 Old 10-07-2013, 4:42 PM Thread Starter
Pretty sure they were black yellow and black green. Looking at that diagram they were the front brake light switch. I appreciate that diagram, I will track down the killswitch wires hopefully soon.
I will also give that yellow box a cleaning, I appreciate that info.
01 929
socci is offline
post #14 of 14 Old 10-18-2013, 7:18 PM Thread Starter
It was the fuel cut relay. I swapped it with the headlight relay and it fired right up. The relay was very corroded along with the plug. All the other relays and grounds look good though. Thanks for the help.
01 929
socci is offline
929 fuel pump wont prime OGDIDDY Honda FireBlade 21 07-30-2013 9:28 PM
929, Fuel pump wont prime afr05h33n Honda FireBlade 11 04-06-2011 1:54 PM
rc has no fi light and fuel pump wont prime fade28 Honda RC51 11 01-13-2011 5:08 PM
F4i fuel pump wont prime CBR600blaster Honda CBR 600 5 11-17-2010 6:51 AM
F4i fuel pump wont prime F4eye Honda CBR 600 0 10-12-2010 8:20 AM
