brake hose length question - Honda Motorcycles - FireBlades.org
post #1 of 12 Old 10-05-2013, 3:53 PM Thread Starter
Reputation Power: 17
Can anyone tell me the length of the rear brake line to the caliper on the 929 and the 954? Also is the master cylinder end of the hose a flat banjo or does it have a 90 degree drop down bend to it?
Thanks
Dan
voodooridr is offline
post #2 of 12 Old 10-05-2013, 4:36 PM
Quoted: 29 Post(s)
Re: brake hose length question
Sorry, I'm at work right now or I would go have a look. Go to the Galfer website and maybe they will have a pic or specifications? G/L
jdoni is offline
post #3 of 12 Old 10-05-2013, 4:38 PM Thread Starter
found pics of the Galfers but you can never be sure that their not just a file photo
post #4 of 12 Old 10-06-2013, 10:36 AM
Quoted: 29 Post(s)
I'll take pic's and measurements this afternoon when I get home from work!
jdoni is offline
post #5 of 12 Old 10-06-2013, 11:02 AM
Reputation Power: 113
Look on a parts fiche site such as Ron Ayers.
Sky91 is offline
post #6 of 12 Old 10-06-2013, 1:22 PM Thread Starter
I'd appreciate that
Dan
post #7 of 12 Old 10-06-2013, 1:28 PM Thread Starter
The problem is it's not going on a 929/954 it's going on a 919 with a RC51 rear caliper and the hose attaches to the rear of the RC caliper and to the front of the 919 caliper making the Galfer line I have on the 919 too short so I need to locate a longer one.
Also I've noticed in my searches that some (russell) of the SS brake line companies use a 90 degree drop down fitting on the master cylinder end and that won't work for what I need.
The joys of modifying
post #8 of 12 Old 10-06-2013, 2:57 PM
Reputation Power: 30
hi, not sure exactly what u want but on a 954 the rear brake hose is 25 & a half inches long (25.5") from master cylinder to rear cylinder banjo centres-lines.
The master cylinder banjo points UP-wards at 45 degrees & IN-board towards the engine - the hose then curves back-wards and down to the caliper.
PEM-954 is offline
post #9 of 12 Old 10-06-2013, 3:10 PM Thread Starter
Pem, that's exactly what I needed to know. I thank you very much
post #10 of 12 Old 10-06-2013, 4:22 PM
Quoted: 29 Post(s)
The Galfer line on my 954 is 25 3/4 inches from banjo bolt to banjo bolt hole.
jdoni is offline
post #11 of 12 Old 10-06-2013, 4:25 PM
Quoted: 29 Post(s)
Here are some pics I took also. G/L
GetAttachment[1].jpg‎   GetAttachment[1] (2).jpg‎
jdoni is offline
post #12 of 12 Old 10-06-2013, 4:32 PM Thread Starter
Thanks guys, you've all helped out a bunch
Rear Shock length question? vertical954rr Honda FireBlade 3 06-21-2014 11:16 AM
Chain length question th3cavalry Honda FireBlade 11 08-04-2013 6:18 AM
06' VT750 vacuum hose question TWOLF Honda Cruisers 0 04-13-2011 8:47 PM
gearing, chain length question 9too9 Honda FireBlade 1 06-25-2006 9:50 AM
exhaust question, hose attachment Paul Honda FireBlade 4 01-10-2004 3:36 PM
