H I S S Problem or Key . - Honda Motorcycles - FireBlades.org
post #1 of 4 Old 10-07-2013, 6:31 PM Thread Starter
Hi folks , after 10 years away from bikes I have purchased an old 2001 fireblade Click image for larger version
Apart from being 10 years older (45) and wiser I am doing ok back on a bike and even the hip pain cramp type thing is getting better after only the 4th time out .
I do however have a problem that seems to be getting worse, my HISS light is getting more and more reluctant to come on, when it does light up green with the ignition being turned on, the pump fires up and it starts straight away.
Unfortunately when I now turn the ignition on I have no light and no pump so no go. Could this be my key ? I only have one key and do need to get another.
I have tried wriggling wires on the barrel but to no affect .
mak24seven is offline
post #2 of 4 Old 10-07-2013, 6:37 PM
Reputation Power: 113
Re: H I S S Problem or Key .
Could be the key, the sensor ring, the wiring of the ring, or the ECU itself. First step is to make sure all electrical connections are clean and tight. And DEFINITELY get another key made - if you lose that one it means forking out for a paired key and ECU (which isn't cheap).
Sky91 is offline
post #3 of 4 Old 10-07-2013, 7:05 PM Thread Starter
Yes , I will go through the connections at the weekend and see how I get on, wasn't actually sure if the key transponder could fail so I guess that is a possibility . I will get hold of Honda this week and order a key although I am guessing they will need the bike to code it , lets hope I get it started :-) .
post #4 of 4 Old 10-07-2013, 7:43 PM
Best place to get a key is on ebay. I got a couple sent in from China for about 5 quid a piece, as opposed to the 40 quid Honda wanted each. Just get em cut at a locksmith's place then. You can either code em yourself using a home made lead (search the site for instructions), or it'll take a dealer about a half hour to do it for ya.
Sky91 is offline
problem Adi29rr General Discussion 7 04-24-2009 7:21 PM
odd problem with my 929 matt baxter Honda FireBlade 1 04-16-2009 9:26 PM
BIIIG OVERHEATING PROBLEM...small brake light problem...WTF!!! temperedtim929 Honda FireBlade 23 03-15-2009 8:08 PM
FI problem guy imikerc51 Honda RC51 4 04-09-2007 11:58 PM
