Throttle tube - Honda Motorcycles - FireBlades.org
post #1 of 6 Old 10-08-2013, 12:09 AM Thread Starter
Reputation Power: 7
Throttle tube
Hey all having a problem on my 97 900rr got new grips in today to get rid of those damn billet aluminum ones they kill my hands so couldn't get off so I just pulled the tube off and the PO epoxied the grip on great so I will be replacing the tube and left clip on I guess. Well I would like to ride my bike until it comes in but I can't get the top cable back on the tube no matter what I tried and tried even took it loose from carbs and put it on then I could not get it back in the carbs so I put it back in the carbs and tried again no luck please guys help me here driving me crazy like its not long enough thank u
Mikew90 is offline
post #2 of 6 Old 10-08-2013, 12:19 AM
Re: Throttle tube
Did you back the top and bottom adjusters off?
post #3 of 6 Old 10-08-2013, 7:20 AM Thread Starter
Reputation Power: 7
Re: Throttle tube
Top one yes bottom little hard to get to
Mikew90 is offline
post #4 of 6 Old 10-08-2013, 7:29 AM
Re: Throttle tube
The bottom one you should just need to crack it loose and then it should turn easily by hand.
post #5 of 6 Old 10-08-2013, 7:34 AM Thread Starter
Reputation Power: 7
Re: Throttle tube
Ok will try thnx blade racer wish the PO didn't epoxy the grips on they loaded it down with it
Mikew90 is offline
post #6 of 6 Old 10-08-2013, 7:41 AM Thread Starter
Reputation Power: 7
Re: Throttle tube
One more question do I just need to loosen the top cable I can see how to do it but the bottom one I can't see to do it so if if I just loosen the top one will that do the trick?
Mikew90 is offline
Air tube mod 08> flatstickHRC Honda FireBlade 0 04-17-2011 5:02 PM
Plastic throttle tube replacement Rhodeislander Honda CBR 600 11 01-17-2011 1:17 AM
throttle tube cross reference nfamousdevil Honda CBR 600 0 05-02-2007 7:39 PM
CBR 929 Throttle Tube Question Ivo Honda FireBlade 4 04-06-2006 4:40 PM
