954 not charging - Honda Motorcycles - FireBlades.org
post #1 of 14 Old 10-09-2013, 11:54 PM Thread Starter
954 not charging
My 02 954 quit charging all of a sudden on the way to work thw other day. I replaced the regulator and still nothing. I checked the stator how the book says to and it shows to be good. I replaced it like last june and I don't know what's up. Thanks for any input
johnb07 is offline
post #2 of 14 Old 10-10-2013, 12:01 AM
Re: 954 not charging
What voltage do you have across the battery with the engine running?
What AC voltage do you have on each of the stator phases?
post #3 of 14 Old 10-10-2013, 12:11 AM Thread Starter
I have to jump it off now but when its running it'll have like 11 volts and slowly be going down. I didn't check ac voltage. I just checked the ohms between each on and checked to make sure it wasn't grounding out. What should the ac voltage be
johnb07 is offline
post #4 of 14 Old 10-10-2013, 12:15 AM
Charge the battery first.
You want something like 50-70VAC from the stator.
post #5 of 14 Old 10-10-2013, 12:27 AM Thread Starter
Ok. Ill check it out first thing in the morning and let you know.
johnb07 is offline
post #6 of 14 Old 10-10-2013, 6:54 PM Thread Starter
Do you go phase to phase or phase to ground?
johnb07 is offline
post #7 of 14 Old 10-10-2013, 8:41 PM
Quoted: 120 Post(s)
Reputation Power: 199
Although I haven't actually tested a stator, I've read several times that you test the three pairs of phases. So phase to phase.
At idle you should get around 12-15VAC. You're looking for consistency more than an actual number. If one of the three pairs is out of whack with the other two, then you have a problem.
Another thing to look for, (again, I've only read this on this forum), is if you remove or replace the stator, you will get some resistance from the magnets as you physically move it. If it slips in and out, theres a problem with the stator.
Bladeracer, does that sound right?
This link may help.
http://www.electrexworld.co.uk/acata...P-PMG-&-RR.pdf
jondog9 is offline
post #8 of 14 Old 10-11-2013, 12:38 AM
This link may help.
Almost perfect Jon :-)
Except, no magnetic resistance indicates a bad rotor, not the stator.
post #9 of 14 Old 10-11-2013, 12:44 AM Thread Starter
So I checked it and its like 1.5 volts ac between all the phases. But I'm not totally convinced its the stator being that the resistance is good and its not going to ground or nothing. So should I just start pulling the alternator apart?
johnb07 is offline
post #10 of 14 Old 10-11-2013, 12:52 AM
Sounds like a fried stator to me.
post #11 of 14 Old 10-11-2013, 4:07 AM
Quoted: 747 Post(s)
Reputation Power: 102
4.5 VAC isn't gonna cut it. Stator is dead. BR is right on with needing somewhere in the area of 50VAC on each leg. That's why you notice the battery voltage dropping while it's running. The normal operation of the bike is taking all the juice from the battery to run and the stator is not replacing it.
IanDoohan is offline
post #12 of 14 Old 10-11-2013, 2:54 PM
Quoted: 120 Post(s)
Ok, 50-70VAC. That's at around 5000rpm - correct?
When I said 12-15VAC, that's at idle.
jondog9 is offline
post #13 of 14 Old 10-11-2013, 2:57 PM
Nope, that's the output you want at idle.
Out of the regulator you'd want 13.5-15VDC.
post #14 of 14 Old 10-11-2013, 3:00 PM
Quoted: 120 Post(s)
Ok, thanks, think I got it straight now.
jondog9 is offline
02 cbr 954 not charging johnb07 Honda FireBlade 1 06-08-2012 12:27 PM
Charging, but not enough!! rosie.s Honda CBR400RR 5 03-10-2011 6:53 AM
not charging like it should filip_sm Electronics 1 10-11-2010 12:50 PM
over charging vtrharvey Honda SuperHawk 2 08-11-2008 4:18 PM
charging ? KevinRR Honda FireBlade 3 04-30-2007 4:24 PM
