Dropped shim while doing valve adjustment - Honda Motorcycles - FireBlades.org
post #1 of 2 Old 10-11-2013, 10:09 PM Thread Starter
Doing a valve adjustment on my 95 900rr ( cylinder 1 intake valve 1 ) and I dropped a shim in that vicinity ( it was seated in the valve top but slipped out of my oily fingers ). Anyone know where that small circular passage way goes on the corner of the head ( again intake 1 valve 1 )? thanks!
Texas900rr is offline
post #2 of 2 Old 10-12-2013, 2:12 AM
Re: Dropped shim while doing valve adjustment
I would guess it drains back to the sump?
Use a magnet when doing shims and cover everything with rags, it's very easy to drop things into the engine.
You can try reaching down the hole with a magnet as it may have got caught by the head gasket if you're lucky.
*Help with valve shim calculation* Hicksi Honda CBR400RR 5 11-24-2013 11:35 PM
valve shim measure ksmutek Honda FireBlade 8 03-15-2011 11:36 AM
valve shim down oil return line santacruzrc Honda CBR 600 1 11-19-2010 8:26 AM
Dropped valve on a '03 954rr azamora954 Honda FireBlade 12 12-23-2005 11:14 PM
Valve Clearance to Shim size chart victoRR Honda FireBlade 2 08-07-2004 10:55 PM
