03 954 problems - Honda Motorcycles - FireBlades.org
post #1 of 4 Old 10-15-2013, 7:36 PM Thread Starter
03 954 problems
So I picked up an 03 954 2 months ago, it wasn't running but I knew it ran. I found loose bolts and hoses so I went through everything to make sure it was right. I got it running decent and wrapped it to 9 grand, it started running like crap and idled like crap then died. Tried starting it again and it didn't start. I took the plugs out cleaned them and it started. Then hit 9 grand and the same thing. I got new plugs and it ran great for a bit and the same thing! So I put a different fuel rail and injectors from my spare motor and nothing still. So next a new fuel pump, still not fixed. I checked for spark, I checked the timing all seemed fine, fuel lines are not pinched. I have not even had the pleasure to ride it yet and I'm running out of patience! If anyone has ideas, suggestions or an answer I'd really appreciate it! Thanks a ton- big kuntry- NM
BIGKUNTRYBLOX is offline
post #2 of 4 Old 10-15-2013, 8:03 PM
Quoted: 159 Post(s)
Reputation Power: 122
Re: 03 954 problems
Were the plugs wet? Or carbon fouled? Was the bike smoking? You may want to read up on checking the FPR.
fj1200rj is offline
post #3 of 4 Old 10-15-2013, 8:19 PM Thread Starter
Re: 03 954 problems
Carbon fouled and the bike was smoking but not bad
post #4 of 4 Old 10-16-2013, 12:28 AM
Re: 03 954 problems
Check the fuel pressure regulator.
You are using fresh fuel I assume?
FI problems mcamp Honda FireBlade 4 02-26-2011 6:42 AM
954 problems Recon 954 General Discussion 3 10-11-2006 9:28 PM
F4i Problems drinktoo Honda CBR 600 13 04-11-2006 4:12 PM
problems with 929 goldy Honda FireBlade 20 12-03-2005 10:34 AM
