954 to 929 - Honda Motorcycles - FireBlades.org
post #1 of 15 Old 10-22-2013, 6:57 AM Thread Starter
954 to 929
Hi Guy's
Can anyone help, I have converted my 954 to 929 due to cannot find a motor for my 954. I have done the conversion but Iam down to the left hand switch for the high beam and indicators. Can any help me out on how to convert or show me a pic of wiring in the 954 wiring into the 929 harness or do I have to use a 929 like everything else?
Laser is offline
post #2 of 15 Old 10-22-2013, 8:06 AM
Re: 954 to 929
Originally Posted by Laser View Post
Hi Guy's
What do you mean you've "converted" the bike?
All you need to do is swap the engine, nothing else at all.
post #3 of 15 Old 10-22-2013, 8:09 AM
Reputation Power: 113
Re: 954 to 929
Hi Guy's
The search function will bring up wiring diagrams. As BR said, just swapping the engine should be fine in itself, provided you didn't get American switchgear for the left bars.
Sky91 is offline
post #4 of 15 Old 10-22-2013, 9:45 AM
Quoted: 129 Post(s)
Reputation Power: 66
Re: 954 to 929
They used the same switch for both bikes......
RRDemon is offline
post #5 of 15 Old 10-22-2013, 10:19 AM Thread Starter
Re: 954 to 929
As I found the wiring harness is completly different and had to be changed the rear light plugs are different the locks had to be changed for the engine as the fuel system wont start aswell the whole thing has to be changed, now Iam down to the last bit and the switch's on the left handle bar are differnt aswell. The only thing the same is the motor it bolts straight in.
Laser is offline
post #6 of 15 Old 10-22-2013, 10:23 AM
Quoted: 129 Post(s)
Re: 954 to 929
Hrm.. I guess fleabay would be the easiest option, or figuring out how to wire everything up from the 54 switch to the 29 switch without having an electrical engineering background... I would say send me the schematics and I'll tell you which colours to connect together =) Getting a 29 loom would probably help, but the sub-looms would also need to be had. Someone link me schematics, the mad scientist must go to work!
RRDemon is offline
post #7 of 15 Old 10-22-2013, 12:26 PM
Re: 954 to 929
So why didn't you simply leave everything stock and just swap the engine?
The 954 has LED tail lights, the bank angle sensor is on the front subframe instead of under the seat, different instrument cluster, and some other differences.
The 929 engine works better with the 954 throttle bodies in my opinion so _only_ swap the engine - nothing else at all.
post #8 of 15 Old 10-22-2013, 12:28 PM
Re: 954 to 929
Replacing the main harness with a 929 harness is a fairly involved job due to the many differences, and a backward step anyway. The 954 ECU and throttle bodies work better.
post #9 of 15 Old 10-22-2013, 12:30 PM
Re: 954 to 929
https://www.fireblades.org/forums/hon...iring+diagrams
post #10 of 15 Old 10-26-2013, 8:39 AM
Re: 954 to 929
To save me starting another thread, am I right in thinking the 929/954 frames are the same, allowing a motor swap without any mods..?
Merc is offline
post #11 of 15 Old 10-26-2013, 8:41 AM
Re: 954 to 929
No, the frames are different.
But the engines are the same so they are interchangeable.
post #12 of 15 Old 10-26-2013, 8:54 AM
Re: 954 to 929
Many thanks Bladeracer, I've come across a low mileage 954 lump with ECU and loom intact, so I'm thinking winter project..!
Merc is offline
post #13 of 15 Old 10-26-2013, 8:57 AM
Re: 954 to 929
You don't need the wiring or ECU, or anything else. You can simply swap the engine.
If you want to swap the harness then you will have to swap other electrical parts to suit.
Compare the wiring diagrams I posted earlier.
post #14 of 15 Old 10-26-2013, 9:02 AM
Re: 954 to 929
Event better!!
I had no idea the ECU was the same on both bikes, would there not have been differences because of the capacity hike from the 929..?
Merc is offline
post #15 of 15 Old 10-26-2013, 9:04 AM
Re: 954 to 929
Event better!!
The ECU is not the same.
But to swap it requires swapping the entire harness.
The small capacity increase has no significant effect.
