Key won't turn ignition - Honda Motorcycles - FireBlades.org
post #1 of 16 Old 10-23-2013, 5:25 AM Thread Starter
Hey guys, I went out tonight to take a ride and my key wasn't working. It took maybe 30 times of pulling the key out and retrying until it finally worked. It only seems to do this when it's cold out. The colder it gets, the more tries it takes. After I get it though, I can shut the bike off or lock the bars and leave the keys in and be fine. Also, my then signals don't like to stay on in the cold. I have to push the button multiple times for them to work properly. Please help as I don't want to pay out the ass to go to the dealer.
Cheezit033094 is offline
post #2 of 16 Old 10-23-2013, 5:53 AM
Reputation Power: 113
Re: Key won't turn ignition
Does the same thing happen with your spare key?
As for the signals, open the switches up and give em a good cleaning.
Sky91 is offline
post #3 of 16 Old 10-23-2013, 5:54 AM
Quoted: 733 Post(s)
Reputation Power: 102
What kinda bike you got there cheesey? Original key? Buggered up cylinder maybe? Has someone tried to steal the bike and possibly jammed a screwdriver in there? If it happens more when cold then I would suspect the tolerance inside the cylinder tightens up, thus making it harder to line up the pins, etc. have you tried wd40 or similar down the old key way? I would also suspect the switch for the turn signals probably needs a little TLC. Take it apart and clean up the contacts and check for separated wires. Clean it up, some dialectric grease on the terminals. If it continues you may need a whole new assembly.
How long has it been doing this?
IanDoohan is online now
post #4 of 16 Old 10-23-2013, 5:55 AM
Quoted: 733 Post(s)
Ah, you snuck in there Sky. I'm slow at the keyboard. lol
post #5 of 16 Old 10-23-2013, 2:06 PM Thread Starter
Original key. I didn't get a spare with it. It's been doing it for the past couple months but just gotten progressively worse. Ill pick up some lube and give it a shot.
post #6 of 16 Old 10-23-2013, 5:02 PM
I had the same trouble.
My key was bent.
I either sat on it in my pocket or was a bit rough with it opening my seat.
white_trash is offline
post #7 of 16 Old 10-23-2013, 8:53 PM Thread Starter
My key was bent.
I'll try to put it in a press
post #8 of 16 Old 10-24-2013, 9:10 AM
Reputation Power: 291
WD40 and a new key, may work?
Irish's Blog Page
Hate this Skin
Assalam-o-Alaikum
setanta is offline
post #9 of 16 Old 10-24-2013, 2:15 PM
Suggest using graphite lube instead of WD40...
TroyN is offline
post #10 of 16 Old 10-24-2013, 2:35 PM
Quoted: 159 Post(s)
Reputation Power: 122
Keys do wear, my bike came with 1 key, the first thing 1 did was go down the street and have a spare made. If your want that OEM Honda look you can order a blank (uncut) key through a dealer for like $8. I suggest you have a spare key made by a good locksmith ASAP, before it gets any worse, for 2 reasons:
1. you said you only have one key, everybody needs a spare, I can think of a couple times I would've been SCREWED without a spare. One time I let a key wear so bad it broke in the ignition, luckily there was barely enough to get side cutters to grab, got a ride home and grabbed my SPARE KEY.
2. everybody loses a key at some point in their life, do you want to pay for a new cylinder then not have it match your trunk?
Spend the $2-$3, save a lot of hassle and maybe some $ later. other than that to all the above suggestions, BTW,I also use graphite lube for locks.
http://www.ebay.com/itm/NEW-OEM-HOND...d6fe92&vxp=mtr
P.S. Never caught any of your previous posts so .
fj1200rj is offline
post #11 of 16 Old 10-24-2013, 3:02 PM
New Honda Key Blank CBR 1000 RR CBR 1000RR CBR1000RR 2004 2005 2006 2007 | eBay
Irish's Blog Page
Hate this Skin
Assalam-o-Alaikum
setanta is offline
post #12 of 16 Old 10-24-2013, 3:21 PM Thread Starter
This weekend, I'll be able to tackle the problem once and for all. My work schedule is a little hectic. Ill use the press at work and get it totally straight, and then make a shopping trip for dielectric grease and graphite lube. I'll order a new blank tonight. Thanks for all your guys' help. I'll keep you updated.
post #13 of 16 Old 10-25-2013, 4:00 AM Thread Starter
Quick update: I got the key totally straight and put the graphite lube in there to no avail. I'm going to order a new blank in a couple minutes.
post #14 of 16 Old 10-30-2013, 6:43 PM Thread Starter
Hey guys, I got the new key in and got it cut and it works great. Thanks for your help.
post #15 of 16 Old 10-30-2013, 7:47 PM
Irish's Blog Page
Hate this Skin
Assalam-o-Alaikum
setanta is offline
fuse blows when i turn the ignition on on a cbr929 looneytunes Honda FireBlade 4 10-07-2012 12:58 PM
Need Help Clear turn marks and rear turn marks dbl Honda Interceptor / VFR 3 04-21-2010 9:26 PM
WTB 06 CBR1000RR Exhuast, Rear Fender With Turn Signals,Front Turn Signals thaiwebb Wanted 5 04-04-2008 3:37 AM
ignition... ls1ssws6 Honda FireBlade 0 09-15-2007 3:41 AM
Ignition Derbarbarian Honda FireBlade 3 09-23-2006 12:30 AM
