vfr750 front wheel into 96-97 sc33 - Honda Motorcycles - FireBlades.org
 1Likes
post #1 of 17 Old 10-23-2013, 3:24 PM Thread Starter
Hi guys just thought I'd share with you my latest modification
I have just fitted a 17" vfr750 front wheel into my 97-98 sc33, mine has the smaller brake rotors diam.295mm and the vfr wheel went straight in using the fireblade axle and spacers.
Hope this is of some use to anyone looking to do the same
kev.basley is offline
post #2 of 17 Old 10-23-2013, 5:41 PM
re: vfr750 front wheel into 96-97 sc33
Is the '97 and '98 Blades not two different models??
I can't remember which one is the S33 both they both aren't the S33 model...
Prunty is offline
post #3 of 17 Old 10-23-2013, 6:05 PM Thread Starter
Hi to be honest im not sure. Mine is registered 98 but it is clearly not the later model but its sc33 on frame and engine no.
But it has the smaller brake rotors and narrower forks. I can get more measurements of any specific area if needed as the rim it only just test fitted before lowder coat etc
post #4 of 17 Old 10-23-2013, 6:09 PM
ive the 918 blade so I know its the 98 model so can kev basely tell me if his bike is same as mine cos I want to know if the 17" wheel will fit as easy as his did and I want to ask about the discs, do I need ones to fit the vfr wheel or do the blade ones fit the vfr wheel?
if kev or anyone can help id appreciate it..... thanks
joycey1 is offline
post #5 of 17 Old 10-23-2013, 6:13 PM Thread Starter
Hi joycey if you can remove the wheel and meaure the distance between fork legs and brake rotor diameter il tell you of mine is the same.
I can get the measurements tomorrow evening and post them here.
With mine I used the fireblade rotors axle and spacers and fits like a glove
post #6 of 17 Old 10-23-2013, 6:16 PM
the front wheel on 92 to 97 blade are different to the 98-99 models.
a 95 cbr 600 wheel is what the early blades used to change up to 17" but that wont work the 98 or 99 model
joycey1 is offline
post #7 of 17 Old 10-23-2013, 6:20 PM
post it when u get a chance, I don't keep my bike at my house so ill have to organise when I can take wheel out, will the manual tell me the size or will I still have to remove wheel?
what do u mean about brake rotor distance, is that the calliper distance?
joycey1 is offline
post #8 of 17 Old 10-23-2013, 6:29 PM Thread Starter
Il measure everything up tomorrow. The diameter of the brake disc. There are two deferent sizes with different offset.
Il get precise results to be sure of exactly what mine is
post #9 of 17 Old 10-23-2013, 6:31 PM
Quoted: 732 Post(s)
Reputation Power: 102
97 is the last 9RR with the steel lower triple clamp. 98-99 Honda went to an all aluminum triple clamp. They also changed the distance between the forks in the new triple design. The modification you did would not work on a standard 98 900RR. Either yours is a 97 or earlier, or your 98 has an older front end on it.
IanDoohan is online now
post #10 of 17 Old 10-23-2013, 6:33 PM Thread Starter
Ahh that would make sense. Mine has the steel lower yolk.
Im trying to get a pic uploaded.
post #11 of 17 Old 10-23-2013, 9:04 PM
Re: vfr750 front wheel into 96-97 sc33
'96-'99 are all SC33, but '96/'97 and '98/'99 are different bikes.
post #12 of 17 Old 10-24-2013, 4:18 AM
Hi Joycey1, my bike is the '98 model and I've done the conversion to 17" front wheel. Pm me your number and I can give you a shout and discuss the conversion with you.
Prunty is offline
post #13 of 17 Old 12-27-2013, 12:01 AM
It would be greatly appreciated if you can post your work on here because I'm not the only one that is very interested in your modification, so please post.
Willidee is offline
post #14 of 17 Old 03-02-2014, 2:44 PM
Hi all. I've fitted a '97 VFR750 17" front wheel to my '97 CBR900RR SC33 Fireblade. It was a clean swap...no adjustments, spacers...nothing. Here's a pic.
Spence96 likes this.
97CBR900RRboy is offline
post #15 of 17 Old 04-10-2015, 8:47 AM
Quoted: 10 Post(s)
Reputation Power: 6
I know this is an old thread, but I'm about to take delivery of a '99 SC33. Can I use a '97 VFR750 front wheel? I've searched the site but this thread is the best info I've found. Thanks. Maybe a definitive list of what works/doesn't could become a sticky at some point
amancalledrob is offline
VFR750 8 spoke wheel & other items saxonblade For Sale 2 09-28-2013 4:14 AM
CBR900RR VFR750 SSSA W/8-Spoke VFR750 Rear Wheel ajdapilot For Sale 3 04-14-2013 5:07 AM
Putting A 916 wheel on a vfr750 swing arm! michaeljsaxton Honda FireBlade 6 02-08-2013 12:18 AM
sp1 rear wheel to fireblade sc33 stephen918 Honda FireBlade 9 08-08-2012 12:13 AM
F3 17in. FRONT WHEEL & WIDEN REAR WHEEL BY KOSMAN FOR CBR 900RR! ajdapilot For Sale 2 06-14-2008 7:46 PM
