02 954 quick jerk - Honda Motorcycles - FireBlades.org
post #1 of 31 Old 10-23-2013, 10:46 PM Thread Starter
Reputation Power: 7
02 954 quick jerk
Alright...so it's happened a few times more recently. I'll be in a low gear 1st or 2nd and very low or easy on the throttle and all of a sudden the bike will "jerk" suddenly wit a quick rise in the rpms.
2nd problem... on the highway between 4th and 5th gear doin maybe 60 than I'll open up the throttle all the way and the bike at first will respond than quickly drop than catch itself and go again. The rpms go up down than up. Again, help?
dazodiac is offline
post #2 of 31 Old 10-30-2013, 1:06 PM Thread Starter
Reputation Power: 7
Re: 02 954 quick jerk
No one huh?
dazodiac is offline
post #3 of 31 Old 10-30-2013, 2:17 PM
Originally Posted by dazodiac View Post
No one huh?
Can you shoot a video of your instruments?
post #4 of 31 Old 10-31-2013, 7:30 PM Thread Starter
Reputation Power: 7
It happens so randomly. . the cct definitely needs to be done but I would assume they have no relation. .??
dazodiac is offline
post #5 of 31 Old 10-31-2013, 8:52 PM
I am unable to visualise what it is you're describing, so I can't guess at possible causes.
For the RPM to rise without the bike accelerating the engine would need to be disconnecting from the transmission, which would tend to indicate a clutch problem.
post #6 of 31 Old 11-01-2013, 7:07 AM
Quoted: 159 Post(s)
Reputation Power: 122
Injector maybe, if it was carbed I might know where to look with those symptoms.
fj1200rj is offline
post #7 of 31 Old 11-01-2013, 5:32 PM
Quoted: 129 Post(s)
Reputation Power: 66
I would think that if it jerks and the RPM rises it is slipping into a lower gear. I have had my 954 do this if I didn't shift positively enough into the next highest gear, but it usually only occurs when I nail the throttle in the next gear. Also leads to a wheelie that I didn't intend....
RRDemon is offline
post #8 of 31 Old 11-06-2013, 11:19 AM Thread Starter
Reputation Power: 7
Sorry I'll try again.
1st gear and barely on the throttle doing maybe 10mph when suddenly the bike jerks as if it shut off and turned back on simultaneously,but it happens in an instant.
Btw, anyone got anything for the other problem I asked about on this thread?maybe they're related. Thanks a million
dazodiac is offline
post #9 of 31 Old 11-06-2013, 11:23 AM Thread Starter
Reputation Power: 7
Also BR..I believe that I definitely need a clutch because whenever I try to clutch it in 1st gear the rear burns out but never catches to bring the front wheel up.. same thing in 2nd gear
dazodiac is offline
post #10 of 31 Old 11-06-2013, 2:48 PM
But it used to come up this way before?
If it is spinning the tyre then I would think the clutch is working fine.
The bike is stock, particularly in wheelbase and ride heights?
post #11 of 31 Old 11-06-2013, 2:54 PM
Are you sure the RPMS flutter like this?
At what RPM are you opening the throttle?
How high do they rise initially?
How low do they fall to before picking up again?
If you're cruising at 60mph in second or third does is still react to throttle this way?
Possibly normal-ish if your gearing is stock as 60mph is right around the point that the engine is starting to breathe.
post #12 of 31 Old 11-06-2013, 2:59 PM Thread Starter
Reputation Power: 7
Well not this 954 but my previous 954 would come up in first gear no problem 2nd also. Bike is stock and I put the whole thing together myself. that being said I believe that the chain link count May be 107 instead of 108 but that should make a big problem right?
dazodiac is offline
post #13 of 31 Old 11-06-2013, 3:12 PM
The 929/954 will come up in first and second without the clutch though, even third is pretty easy.
Only problem is that it's impossible ;-)
It'll either be 106 or 108 links, even numbers only.
post #14 of 31 Old 11-06-2013, 3:31 PM Thread Starter
Reputation Power: 7
106/108 Gotcha. And sure you can power wheelie in 1st. But why would the wheel spin under me in stead wheelie when clutching in first? Regardless I don't wanna get off subject,but do wanna change the clutch if it's a problem for the above problems
dazodiac is offline
post #15 of 31 Old 11-06-2013, 3:35 PM
Not power wheelie, just bounce the front up at about 5000RPM in first, second and third.
Could be lots of things, suspension too hard, tyre pressure too high, bald tyre, loose chain, worn cush drive, lots of things.
Bike jerk when its on red line vrudog Honda FireBlade 19 03-31-2013 5:17 PM
THROTTLE JERK. KNOXCBR General Discussion 2 06-07-2008 3:28 PM
The Jerk ConqSoft Off-Topic 4 02-04-2006 9:58 AM
Getting screwed by jerk that hit my cage BladeRider Off-Topic 6 03-11-2004 11:18 AM
Mat Mladin might not be a complete jerk CBRVFR Off-Topic 12 09-29-2003 6:37 PM
