Help! Wiring terror - Honda Motorcycles - FireBlades.org
post #1 of 3 Old 10-29-2013, 3:58 PM Thread Starter
Help! Wiring terror
Hi guys and gals I could use some help maybe you've seen this before.
I have a 2000 929 bike but the motor is a 2002 954, it was running fine for the 2 years I had it from 2010-2012 but one day it died on me as if it ran out of gas. I took it to the dealer and they said I had a short around my fuel pump but they also found my wire harness was burnt up and melted. They said it was due to the wiring difference from the fans in 2000 and 2002. I'm wondering if their is a conversion harness out there of if my best bet is to get a heavier duty harness and just rig it together using the two different diagrams like the other guy did.
Thanks, Jordan
FrankinBlade is offline
post #2 of 3 Old 10-29-2013, 4:03 PM
Re: Help! Wiring terror
Thanks, Jordan
Does the fuel pump work?
If the harness is melted then I would just replace it, or at least replace the damaged section.
You shouldn't have two different harness though, the harness should be the original 929 harness.
post #3 of 3 Old 10-29-2013, 4:35 PM Thread Starter
The pump is a good pump and works and before they replaced the burnt up harness if they grounded the fuel tank to the bike the bike would run but after they replaced everything it wont start at all.
Tags
929 , 954 , fireblade , harness , maintenance
Terror Plot Foiled!! gthotchkiss Politics 103 08-17-2006 12:59 PM
Better raise the terror alert... ND4SPD Off-Topic 10 02-02-2005 6:40 PM
Terror threat testing soon2b954 Off-Topic 3 10-01-2004 10:53 AM
Can't win the war on terror... TAZ Politics 4 09-02-2004 3:22 PM
French Terror Alert ConqSoft Politics 4 08-20-2004 10:53 AM
