Headlight relays ? - Honda Motorcycles - FireBlades.org
post #1 of 6 Old 01-21-2014, 2:12 PM Thread Starter
Headlight relays ?
Are these really necessary ?
Looking to remove them, to save bulk behind streetfighter headlamp unit !
First bike I've had with them, so assume they can be switched straight from the switch itself ?
Cheers.
Rob
rob.b.666 is offline
post #2 of 6 Old 01-21-2014, 5:14 PM
Re: Headlight relays ?
Cheers.
Rob
You might have to beef up the wiring and the switch.
Relays close high current circuits via a low current circuit.
post #3 of 6 Old 01-21-2014, 6:56 PM
Quoted: 120 Post(s)
Reputation Power: 198
You're putting the full load on the switch. It might not handle the amperage. That's why they use the relay- to let it do the heavy work.
jondog9 is offline
post #4 of 6 Old 01-23-2014, 5:20 PM Thread Starter
Will have a look at the switchgear.
May wire the dipped beam to the sidelight, as new headlight doesn't have a sidelight, so should be able to do away with the dipped beam relay and just keep the high beam relay ?
post #5 of 6 Old 01-24-2014, 10:28 AM
Why not relocate the relay to the back of the bike and run new wiring to the headlight?
Bluevitz_RS is offline
post #6 of 6 Old 01-24-2014, 8:12 PM
Quoted: 120 Post(s)
Better run a pretty heavy main power wire. At least 12AWG. Of course, switch power can stay small, like 18AWG.
But that's a better idea than eliminating the relay.
jondog9 is offline
954 Headlight cowl and Headlight on 929 - is it possible Nav Honda FireBlade 12 10-24-2011 7:11 PM
moving relays / fusebox on a CBR900RRW Dixienormouse Streetfighter 4 06-06-2011 10:48 PM
rrp headlight relays greenhearts54 Electronics 0 02-20-2010 6:59 AM
'93 cbr 900rr relays acordes Wanted 0 12-24-2008 4:52 PM
F3 HEADLIGHT AND MAYBE HEADLIGHT FAIRNIG STAY appel_1978 Wanted 3 12-11-2008 6:44 PM
