95 900rr ignition wiring? - Honda Motorcycles - FireBlades.org
post #1 of 8 Old 01-21-2014, 10:56 PM Thread Starter
Bought a 95 900RR with some chopped up wiring , particularly the ignition area, I can seem to figure out where most of the wires go except the one black wire coming off the ignition switch, I have a manual but as far as I can tell there is no black wire? Anyone have a close up picture by chance?
keith5064 is offline
post #2 of 8 Old 01-22-2014, 9:30 PM Thread Starter
Re: 95 900rr ignition wiring?
not the best picture but it shows the black wire which is coming off the ignition switch, also there seems to be an extra pink wire?
IMG_20140120_163425_586.jpg‎
post #3 of 8 Old 01-23-2014, 2:32 AM
Quoted: 4 Post(s)
Reputation Power: 77
Hi Keith, I will have a look at the manual later for you. I can tell you the pink wire is for a security diod to stop the bike being hot wired, the ecu checks for this before it allows the bike to be started. Do a search on here about the pink wire and you will find the info.
Are you sure that black one hasn't been added that ignition looks rather hacked about?
http://youtu.be/2ISgxtQXs9o
My 900RR Winter Project
Lambchops is offline
post #4 of 8 Old 01-23-2014, 7:58 AM Thread Starter
Looked through about a dozen posts trying to figure out where that darn pink wire goes to..haven't really come up with much, I do know its neccesary for operation.
- the black wire comes straight out of the loom coming from the ignition switch...
post #5 of 8 Old 01-23-2014, 8:41 AM
Quoted: 4 Post(s)
The pink goes to a diode.. not sure wheres thats located mind but it wont fire without it. What excactly are you doing changing the ignition or just tidying up the wires?
post #6 of 8 Old 01-23-2014, 9:55 AM Thread Starter
Just trying to put the cut wires back together to get it to run...
post #7 of 8 Old 01-24-2014, 7:31 PM Thread Starter
so from what i can tell, looks like someone replaced the ignition switch with an aftermarket job and tried to splice the wires back together which arent quite the same, so ill try a stock one...
post #8 of 8 Old 01-25-2014, 3:04 AM
Quoted: 696 Post(s)
Reputation Power: 102
I'm fairly certain on the US 95 model the pink wire came out of the ICM/ECU and went right into a ground. I don't think Honda had that ready for the 95 model year yet. Pretty sure the pink wire up by the ignition is for the speed sensor. Do a search for wiring diagrams on this site. Bladeracer has them up in a thread somewhere. I've downloaded them, but not to my phone.
Update, Hahahaha. I just noticed the wire diagrams are a STICKY. Top of the page.
Last edited by IanDoohan; 01-25-2014 at 3:26 AM. Reason: Found sticky for wire diagrams.
IanDoohan is online now
Ignition Wiring Question Yorke Electronics 2 06-24-2013 4:11 AM
Wiring schematic for Ignition system on a 0030-MJ1a-6700 jeffb General Discussion 16 05-02-2013 10:38 AM
98 cbr900 Ignition????????Anyone have a wiring Diagram?? BikerBoy09 General Discussion 4 09-20-2011 11:47 AM
help wiring rfid ignition to my cbr954 rubbersdown General Discussion 3 08-23-2011 11:35 PM
1973 cb 750 ignition coil wiring freezincold519 General Discussion 2 12-10-2010 5:31 PM
