2008 1000RR - got the crank noise, past the warranty extension. Is this detrimental? - Honda Motorcycles - FireBlades.org
post #1 of 4 Old 01-23-2014, 4:32 PM Thread Starter
Hi, new guy here but I've creeped for a while.
Picked up an 08 blade in pristine condition a few thousand miles ago. No oil burning, but just recently I have started to hear the famous "tractor idle" from the clutch. Did the clutch loading test and sure enough the engine quieted right up.
My bike is past the 5 yr from purchase mark... So what should I do?
I know the recall letter says it doesn't affect "performance or reliability" and hell, that super charger "weeeeeeiiiiiiiiing" sounds badass, but I don't want a crank failure.
Anyone else riding a current gen blade that didn't get the replacement?
Thanks
RedRocketRR is offline
post #2 of 4 Old 01-28-2014, 5:17 AM
Re: 2008 1000RR - got the crank noise, past the warranty extension. Is this detriment
Thanks
How does a clutch issue cause crank failure?
As long as the clutch rattle stops when you load it up I wouldn't worry about it.
post #3 of 4 Old 01-28-2014, 8:56 PM Thread Starter
Thanks for the reply.
I'm a little confused on that as well, but it seems that the clutch rattle is caused my the deformation of the crank/primary drive teeth.
I dont care about the noise, I just dont want teeth on the crank to break and grenade my motor.
post #4 of 4 Old 01-29-2014, 12:57 PM
Quoted: 29 Post(s)
Reputation Power: 12
Recalls are not time limited in UK, are they in TX?
Spaz is offline
Tags
1000rr , crank , crankshaft , engine , noise
Gear noise on the 1000RR Max Honda FireBlade 5 03-18-2014 6:37 PM
chain noise 06 1000rr CBRob2006 Honda FireBlade 3 07-18-2012 1:11 PM
2008 1000rr fireblade (engine noise problem) pls help fireblade_2008 Introductions 6 11-04-2009 3:11 PM
2008- Camshaft problem - Ticking noise Zuhnu99 Honda FireBlade 1 02-06-2009 11:42 AM
2008 past away at only 4 months sweet1070 Wrecked Motorcycle Photos & Stories 8 09-17-2008 6:14 PM
