1996 RRV Carb set up idle drop check !! - Honda Motorcycles - FireBlades.org
post #1 of 4 Old 01-31-2014, 5:43 PM Thread Starter
Reputation Power: 9
Ok, I've now got brand new pilot, main and Needle jets in my carbs and they're well balanced.
Just wondered has anyone done the Idle mixture drop setting that's listed in the Clymer manual but not in the Haynes manual. I've just got my air fuel screws wound out 3 turns.
Yes I know I should have counted them in when I started but had never heard of the idle drop setting.
Does it achieve much ?
Flashhart is offline
post #2 of 4 Old 01-31-2014, 8:23 PM
Re: 1996 RRV Carb set up idle drop check !!
Blip the throttle, the tach should drop straight back to idle.
If the revs hang up then the mixtures are lean.
If the revs drop below idle then pick up then the mixtures are rich.
post #3 of 4 Old 02-01-2014, 10:00 AM Thread Starter
Reputation Power: 9
Ok thanks, seems simple enough. Since I put new jets and needles in it and balanced the carbs it runs great was just wondering about the mixture and the method in the Clymer manual seems long winded to me.
I'll go and warm her up and try blipping it.
Thanks for the advice
post #4 of 4 Old 02-04-2014, 7:03 PM Thread Starter
Reputation Power: 9
Warmed her up tonight, blipped the throttle and she's beautifully smooth. Just rises nice and smooth and settles back to exactly the same idle, no hang up and no drop so think I might just ride it and see what she's like. If it ever stops raining !!
1996 RRT Carb Balance Flashhart Honda FireBlade 0 01-26-2014 3:32 PM
98 900RR: #4 cylinder chatter, hear exhaust from carb, unstable idle, wont rev high relliMmoT Honda FireBlade 3 09-26-2010 1:15 PM
Idle air screw and carb cleaning. Nycbr600f2 Honda CBR 600 16 06-14-2010 1:25 PM
Check out my 1996 900RR jwmurra6 Review My Ride 5 12-30-2008 9:02 AM
Idle drop procedure/95 900RR pajazo Honda FireBlade 3 06-26-2007 3:42 AM
