02 954rr winter refresh - Honda Motorcycles - FireBlades.org
post #1 of 93 Old 01-31-2014, 7:34 PM Thread Starter
Reputation Power: 7
Sup everyone. I am sending my frame to get powder coated so while everything is exposed I wanna do whatever I can to "freshen up" the engine. For example I'm definitely doing the cam chain tensioner and the fuel pressure regulator. Is there anything else I could do that may be helpful? Thanks in advance.
P.S. shopping for the cct, I can only find the manual. Where can I find the automatic cct? Ty
dazodiac is offline
post #2 of 93 Old 01-31-2014, 7:36 PM
Re: 02 954rr winter refresh
Valve clearances would be the obvious one.
Try Ronayers.com?
post #3 of 93 Old 01-31-2014, 7:45 PM Thread Starter
Reputation Power: 7
Try Ronayers.com?
Im not afraid to tackle it myself. .. question is...is that something I could/should do myself or have someone do it for me?
dazodiac is offline
post #4 of 93 Old 01-31-2014, 7:47 PM
Checking the clearances is not difficult but read the manual first to decide if you're comfortable with it.
Swapping shims is a little more complicated but still not difficult.
post #5 of 93 Old 01-31-2014, 8:18 PM Thread Starter
Reputation Power: 7
I'll order a manual now lol. Any answers on where I get an auto cct? And is there anything else I can do?
dazodiac is offline
post #6 of 93 Old 01-31-2014, 8:19 PM
Any Honda dealer can supply the CCT.
Ronayers.com are a good choice but there are lots of others.
post #7 of 93 Old 02-01-2014, 9:08 AM Thread Starter
Reputation Power: 7
With the cct,all I need to change is the tensioner? No guide,chain, etc?
dazodiac is offline
post #8 of 93 Old 02-01-2014, 9:10 AM
I would assume you are replacing the tensioner because it has failed?
If other components have also failed then replace those also.
post #9 of 93 Old 02-01-2014, 1:49 PM Thread Starter
Reputation Power: 7
Well there's a noise and I just wanna trouble shoot it.i haven't taken it apart yet,but the noise had been bothering me all summer.
dazodiac is offline
post #10 of 93 Old 02-10-2014, 6:34 PM Thread Starter
Reputation Power: 7
Hey blade,I'm on Amazon looking for a feeler gauge. Do you know which one I should buy? Thanks
dazodiac is offline
post #11 of 93 Old 02-10-2014, 9:54 PM
Quoted: 695 Post(s)
Reputation Power: 102
You can get a set of feeler gauges from any auto parts store. Just make sure they include the sizes you need. For example I think the ones for the 93 900RR are .006 and .008 in. I use the wide ones that look like a tongue depressor. The feeling end is bent at an angle to get in there better. You'll need to check the manual for the sizes you'll need for a 954.
My Red Rocker 93 Build Link: Caf 900RRP
IanDoohan is offline
post #12 of 93 Old 02-10-2014, 10:05 PM Thread Starter
Reputation Power: 7
Thanks Ian... intake is .13 to .19 and exhaust is .24 to .30mm
dazodiac is offline
post #13 of 93 Old 02-10-2014, 10:33 PM
Quoted: 695 Post(s)
No worries, so just make sure the ones you buy have one to get the middle number of your spec. Valve clearance inspection is good intimate time spent with your motor too.
post #14 of 93 Old 02-10-2014, 10:38 PM
Or that add up to the required thickness, you can use more than one strip ;-)
post #15 of 93 Old 02-11-2014, 11:46 AM Thread Starter
Reputation Power: 7
Just in time for Valentines Day. Isn't that nice
I just gotta figure out which ones are exhaust and which ones are intake.
Don't mind me if I ask dumb questions.
dazodiac is offline
CBR929rr body mod and refresh engine Hung Honda FireBlade 6 01-05-2016 12:37 PM
engine refresh Slycrew Honda FireBlade 11 04-21-2014 4:51 PM
WHAT DO YOU DO TO SEE IN THE WINTER ronmorgan General Discussion 12 02-14-2009 4:16 PM
necessary to refresh coolant 929RR? timace Honda FireBlade 7 03-24-2006 8:58 AM
Welcome to winter... ND4SPD Off-Topic 32 12-06-2003 10:23 PM
