Chain and sprocket issues? - Honda Motorcycles - FireBlades.org
post #1 of 10 Old 02-05-2014, 2:30 AM Thread Starter
Reputation Power: 6
Hello again people, I have an issues, I want to buy a chain and sprocket kit, for my 2007 CBR 1000RR and im getting a lot of mixed signals about what to buy! I would like to go Front 15T and rear 44T (stock is 16 and 42 apparently) so I want some quicker acceleration, wanna try some wheelies abit easier yadda yadda yadda! But the guys at the shop said I had a 540 chain? every were I looked said I had a 530 chain and there is some kits on eBay for 520?? I no there is a conversion although not whats involved exactly but if money wasn't an issue, what would you do? what would use buy?
mkhulls12 is offline
post #2 of 10 Old 02-05-2014, 4:40 AM
Re: Chain and sprocket issues?
There is no such thing as 540 chain, find a better shop.
You can swap to high-quality 520 chain and sprockets to reduce unsprung weight and driveline mass.
There is nothing special involved in swapping from 530 to 520 or anything else, as long as the chain and sprockets are the same pitch.
post #3 of 10 Old 02-05-2014, 4:53 AM Thread Starter
Reputation Power: 6
Is it worth deviating from the factory?
post #4 of 10 Old 02-05-2014, 6:15 AM
Depends on how you measure "worth".
Lowering the gearing will use more fuel and increase your speedo error, but makes for a more enjoyable ride in my opinion.
Going to 520 the chain and sprockets are likely to wear slightly faster but you get a little better feel to the suspension and throttle, and save about 1kg of weight.
You get similar effect to lowered gearing by simply riding in a lower gear.
post #5 of 10 Old 02-05-2014, 6:41 AM Thread Starter
Reputation Power: 6
oh man the speedo I forgot!
post #6 of 10 Old 02-05-2014, 6:58 AM
Quoted: 6 Post(s)
Reputation Power: 26
Up to you, but in my opinion, if it is time for new chain and sprockets, there is no justification for staying with the 530, so might as well go 520, and the change of gearing will make the bike even more fun, so why not.
Just don't forget that your speedo will be even more optimistic than with factory ratio.
ghbzorro is offline
post #7 of 10 Old 02-05-2014, 7:08 AM Thread Starter
Reputation Power: 6
Ever used a speedo healer before?
post #8 of 10 Old 02-05-2014, 7:09 AM
Nope, I do the math in my head :-)
post #9 of 10 Old 02-05-2014, 1:16 PM
Quoted: 120 Post(s)
Reputation Power: 198
-1+2 is a good ratio to start with. That's what's on my RC51. So much friendlier for everyday and weekends than the taller stock sprockets.
Today's 520 chains like DID-ERV3 are more than strong enough for our liter bikes. That's what I've been running for about 3 years now. Like Bladeracer says, you save about 2 lbs of rotational mass.
I have a speedohealer. I found my correction factor to be about 11%, then she's really close to actual speed, according to my GPS.
jondog9 is offline
post #10 of 10 Old 02-05-2014, 1:23 PM
Quoted: 120 Post(s)
btw, as you can see from the chart below, 530 is not any stronger in theory, than 520.
Look at the size of the pins. Same as the 530. The sideplates are identical too. It's just a narrower chain. The components are the same.
jondog9 is offline
Tags
1000cc , acceleration , chain , speed , sprocket
Chain and sprocket issues Jhavener General Discussion 2 08-16-2013 2:50 AM
f4i chain/sprocket Dblock55 General Discussion 3 07-15-2010 7:26 PM
01 929 Chain and Sprocket ETSLOSS Introductions 1 11-22-2008 12:10 PM
what is you sprocket chain set up? why? NumBrEleVeN Honda FireBlade 28 09-15-2007 2:01 PM
sprocket/chain geneva8993 Honda Off-Road 1 03-22-2007 1:34 PM
