APE manual tensioner help please - Honda Motorcycles - FireBlades.org
post #1 of 6 Old 02-08-2014, 3:43 PM Thread Starter
FNG
Reputation Power: 7
Hi guys, well the weekend is upon me and since I have my new torque wrench I reckon it's time to replace the CCT with the APE.
now am I better removing the valve cover to do this (the rad and exhaust are off anyway) or should I just remove the old CCT and replace without disturbing any of the components?
I know removing the cover would allow me to keep an eye on the chain incase it jumps but I'm a little unsure as I'm not exactly a confident mech so disturbing the valve cover is a quandary for me............
FNG
FNG is offline
post #2 of 6 Old 02-08-2014, 4:08 PM
Reputation Power: 6
Re: APE manual tensioner help please
it should be fine. there is no way your cam chain should ever be loose enough to jump a tooth without removing a cam or gear. i just went though a cam chain problem... it was TO TIGHT lol.
anyway you should be completely fine. dont go turning the motor over though when you have the tensioner out.
honestly i never understood why people would want a take that tensioner out for a manual one. its more of a hassle IMHO. but whatever makes you happy i guess
lrayford is offline
post #3 of 6 Old 02-08-2014, 5:02 PM
Reputation Power: 34
They can and do fail. Not as often as on bikes like the VTR1000f, but still it can be a problem.
Here's one I took apart to find out why - turns out the insides were a bit rusty, and the spring was also maybe a bit compressed.
amorti is offline
post #4 of 6 Old 02-08-2014, 6:27 PM
Reputation Power: 6
well anything can fail i guess, manuel or automatic.
i just look at it like this 1. you cant put to much pressure on the chain with auto tensioner. 2 you don't have to maintenance the auto tensioner.
if the auto tensioner does fail the chain will become loose over time and you will start to hear the "ticking" cam chain noise.
if the manual tensioner needs to be adjusted your going to still know its time by the same ticking noise. but instead of replacing the auto tensioner.( maybe once, ever in the race case) every time the manual tensioner becomes loose you have to get your hands in there and to me the easiest way is lift the tank and air box. and i don't know about you but i don't like taking my tank off any more then i have too.
again this is just my opinion and not to thread jack. but remove the auto tensioner and go ahead and put your manuel one in. you'll be fine with out removing the valve cover like i said.
lrayford is offline
post #5 of 6 Old 02-08-2014, 9:22 PM Thread Starter
FNG
Reputation Power: 7
thanks, I should have mentioned, it's not a CBR600 I have but a CB900RR-S 900 (95).............
FNG
FNG is offline
post #6 of 6 Old 02-09-2014, 10:02 AM
On the 900 it's a piece of cake to get to the tensioner. You will get better access if you remove the RHS mid panel, but it's not required.
amorti is offline
cbr 900 rr manual cam tensioner nof900RR Honda FireBlade 10 08-09-2012 6:34 PM
Manual cam chain tensioner MTXMUGEN Honda FireBlade 6 04-26-2012 2:38 PM
APE Manual Camchain Tensioner nuton2wheels For Sale 0 07-18-2011 1:59 AM
APE manual cam chain tensioner ubfast98 Aftermarket Perfomance Parts Reviews 6 05-08-2011 9:33 PM
929/954 APE manual cam chain tensioner someoneandhis929 For Sale 5 03-29-2007 8:21 AM
