Are 929 and 954 yokes the same? + brakes.. - Honda Motorcycles - FireBlades.org
post #1 of 7 Old 03-05-2014, 9:02 AM Thread Starter
Hi Fellow Blade lovers..
Im in the process of converting my 900 to a new front. I have bought some 929 forks, and im now looking for the lower yoke.
So my question is does the 929 and 954 have the same yokes? Or will only the 929 yokes work?
And should i go for 929 or 954 brakes? i can see there is a difference in piston size..
Any input is appreciatet
Kind regards from Denmark
Juel-dk is offline
post #2 of 7 Old 03-05-2014, 11:14 AM
Re: Are 929 and 954 yokes the same? + brakes..
What I've found while researching the RC51 fork swap for my 919 is that the 929/954 yokes are interchangeable.
The calipers have different sized pistons but are externally identical, as long as you use the matching master cylinder you'll be fine
voodooridr is offline
post #3 of 7 Old 03-05-2014, 1:09 PM
Reputation Power: 34
If your own brakes still work, you can use them too.
amorti is offline
post #4 of 7 Old 03-07-2014, 3:14 AM Thread Starter
Hi Thanks for you answers So the 929 breakes as good as the 954?
My own master needs rebuilding, and I wanted to do an upgrade Thats why im looking at 954 breakes
Perfect with the yokes, ill try to find a cheap one
Juel-dk is offline
post #5 of 7 Old 03-07-2014, 3:34 AM Thread Starter
Ohh and the NeXT problem... I have a NC40 frontwheel on the sc28 atm. and the 954 rotors are 330mm is it posible to fit 330discs on the nc30 Wheel, do anyone know the bolt pattern size on a cbr 929/954?
Juel-dk is offline
post #6 of 7 Old 03-07-2014, 10:59 AM
110mm bolt circle
From the Metal Gear website
Outside Diameter330Inside Diameter94Bolt Hole Circumference110Bolt Hole Quantity6Bolt Hole Size6.5Thickness4.5Minimum Thickness3.5Offset12.5Type of Bolt HolesSTRAIGHT
post #7 of 7 Old 03-07-2014, 12:39 PM Thread Starter
Ok thanks
So I need an SP1 front Wheel, or make some special discs for my Wheels..
Thanks for your help
Juel-dk is offline
What USD forks and yokes for my CBR 400rr NC29? BerryBlade Streetfighter 15 01-13-2013 8:04 AM
Brakes RepsolRob929RR General Discussion 6 05-05-2012 4:45 PM
954 forks and yokes - UK tropsove Wanted 1 04-28-2010 11:50 AM
Trick forks/yokes/wheels/brakes... Evogixer Review My Ride 8 04-27-2010 5:05 AM
I'm looking for 954/929 behind yokes Nono_ Blackbird For Sale 9 12-19-2005 7:16 PM
