98 fireblades main fuse? - Honda Motorcycles - FireBlades.org
post #1 of 5 Old 03-09-2014, 6:38 PM Thread Starter
Can anyone tell me what this is called?
And anyone have one to sell, with the connector too?
MurdaJ is offline
post #2 of 5 Old 03-09-2014, 9:17 PM
Reputation Power: 34
Re: 98 fireblades main fuse?
It's the starter solenoid. You will likely have to replace the connector with 8mm female blade terminals.
amorti is offline
post #3 of 5 Old 03-10-2014, 10:30 AM Thread Starter
Thank you. Beside the corrosion and melted plastic, it also rattles inside.
When I put the key in the ignition, it's completely dead. No lights, nothing, even when I tried to jump it. Could the starter solenoid be the culprit?
MurdaJ is offline
post #4 of 5 Old 03-10-2014, 11:01 AM
Yes.
When you replace it, you should also be careful regarding the regulator, stator and battery. If the solenoid shorted it could have melted any or all of those too. Start by cleaning and silicon greasing (not mineral grease!) all associated plugs, charging the battery and checking if it holds charge.
amorti is offline
post #5 of 5 Old 03-10-2014, 11:06 AM Thread Starter
Thanks for the advice, I have the part ordered, should be here in two days. I'll post up results.
Thanks again!
MurdaJ is offline
main fuse keeps blowing BigBlu General Discussion 2 07-17-2012 3:01 PM
NC 23 1989 Main Fuse keeps blowing Brzous Honda CBR400RR 12 04-12-2011 3:38 PM
93 cbr900RR main fuse box help.... 93900RR Honda FireBlade 2 03-01-2011 7:13 PM
main fuse/ Rectifier gary66 Honda FireBlade 6 04-09-2009 6:22 AM
Help needed blown main fuse SP2MAN Honda RC51 2 12-26-2007 6:06 AM
