98/99 Fork oil issue - Honda Motorcycles - FireBlades.org
post #1 of 4 Old 03-12-2014, 6:30 AM Thread Starter
Hi all, I wonder if anyone can help.
I have a 97 machine with a later 99 front end in fitted by the previous owner. It does indeed have the later brakes and bottom yoke to support this
I've just renewed the fork seals but I'm struggling with oil fill levels/air gaps.
The only information I can find is for post 97 bikes which states oil fill capacity is 540cc with an air gap of 114mm.
When I put 540cc of oil in I have an air gap of 147mm which is way off the mark. Measurement has been taken with the no spring fitted and the fork fully compressed.
I presumed the 540cc would be a starter fill capacity which is then fine tuned by checking/setting the air gap.
Any one had issues like this before or is my post 97 specs incorrect?
Dave893 is offline
post #2 of 4 Old 03-12-2014, 7:08 AM
Re: 98/99 Fork oil issue
Did you stroke the damper rod to bleed the air out, and is the damper rod fully compressed as described in the manual?
I would just fill to the specified level, volume is irrelevant.
post #3 of 4 Old 03-12-2014, 10:17 AM Thread Starter
Hi bladeracer, yes, the damper has been well stroked to remove any air.
Reading around the web the key measurement seems to be the air gap (level) and not the volume fill quoted. This obviously begs the question of why quote a fill capacity if it is (in this case) inaccurate?
Dave893 is offline
post #4 of 4 Old 03-12-2014, 10:32 AM
The same reason they quote a volume for the engine oil and coolant, so you have some idea of how much you'll need. But the volume is not relevant, the level is.
'12 cbr1000rr front fork issue Razz Honda FireBlade 14 04-06-2013 4:01 PM
04 600rr Fork Disassembly Issue burner303 Honda CBR 600 3 05-07-2011 2:36 AM
954 Fork Issue KSJNX Honda FireBlade 11 12-09-2009 12:31 PM
Might have fork issue and need HELP biggup21 Honda FireBlade 5 06-28-2008 9:54 AM
1000rr Front Fork Issue The Closer Honda FireBlade 2 03-25-2008 5:06 PM
