954 Engine Question - Honda Motorcycles - FireBlades.org
post #1 of 6 Old 03-15-2014, 10:03 AM Thread Starter
Quoted: 27 Post(s)
Reputation Power: 10
954 Engine Question
Do you think I should rebuild this engine do to the cylinder wall scoring or would it be okay to run for this season and then rebuild next winter. I ask because my funds are low and it would take several more months to get the bike back on the road. The engine was ticking so the PO took the head off and found this scoring. He said the bike ran fine before he took the head off with no power loss, just ticking while idling in neutral. He also showed me videos of the ticking and him riding the bike to prove his point.
msebastianCBR is offline
post #2 of 6 Old 03-15-2014, 12:08 PM Thread Starter
Quoted: 27 Post(s)
Re: 954 Engine Question
A little more info, the engine turns over just fine with no issues and does so smoothly. The engine has a little over 10,000 miles and was a 1 owner bike before I purchased it. The bike as far as I know has not been raced and I will not be racing or running the bike too hard either. I will also be completely cleaning up the top of the block as well as the pistons as much as possible. The head has already been sent off for a complete cleaning and to have the valves polished and lapped in and reassembled.
If the masses feel that the engine should be rebuilt than I will do so it will just put me another month or two behind. I have plans to rebuild the engine but was hoping I can get by until next winter.
post #3 of 6 Old 03-15-2014, 3:33 PM
I've seen worse.
2001 Erion 929 Race Bike
1998 Ducati 748
2002 CR125/CR500 Aluminum Conversion
1994 CR500 Completely Built
2000CR250/CR500 Conversion In Process
1950 Indian Warrior 500cc Vertical Twin
1995 Mustang Cobra Turbo Built 820rwhp/879ftlbs
zfrilly3 is offline
post #4 of 6 Old 03-16-2014, 4:39 PM Thread Starter
Quoted: 27 Post(s)
119 views and 1 response. What would you do if the cylinder walls had scoring like this. I can barely catch a nail on a few of the grooves throughout the 4 cylinders.
post #5 of 6 Old 03-16-2014, 4:59 PM
Since you plan on rebuilding next winter run it. Worst case is it looses power or seizes up. I have seen worse that were still running. It shouldn't cause any further damage to keep running it. That scoring is very minor and not what was causing the ticking at idle.
1998 Ducati 748
zfrilly3 is offline
post #6 of 6 Old 03-16-2014, 5:21 PM Thread Starter
Quoted: 27 Post(s)
Yeah I listened to the video the PO took and compared it too some other videos where the tensioner was at fault for the ticking and I think it is the tensioner. So when I put everything back together I am going to put a manual tensioner on it and hopefully have no ticking. I am also doing the pair mod. The htev has already been removed as well as the flapper and a servo buddy has been installed.
954 Engine question Babongita General Discussion 17 05-23-2012 2:49 PM
Engine question tach9 Honda CBR400RR 2 04-05-2009 5:13 PM
Spare Engine question deez General Discussion 12 03-01-2005 3:09 PM
954 engine question chrisbratton22 Honda FireBlade 1 03-15-2004 12:39 PM
