2004 CBR1000RR rough running - Honda Motorcycles - FireBlades.org
post #1 of 9 Old 03-22-2014, 12:49 PM Thread Starter
I have just got my bike out after winter here, did an oil change and pumped the tyres up, usual stuff.
Took it out for a ride and it was running fine, but after 15-20 mins I noticed it wasn't as smooth and when I slowed for a roundabout it feel very rough and was sounding like a twin.
Believe its misfiring but not sure why.
I didn't get an FI light or anything.
Topped up with fresh fuel but no change still seems rough.
I have started to strip it down to check the plugs but wanted to know if anyone had any suggestions? had problems like this before?
Adam_W is offline
post #2 of 9 Old 03-22-2014, 10:39 PM
Re: 2004 CBR1000RR rough running
I don't know how topping off fuel fixes the bad fuel in the tank already. It's perhaps contaminated and all you did was increase the quantity of perhaps bad fuel. DRAIN the bad fuel, add nothing but fresh fuel, and you will have at least ruled out fuel, finally. Topping off does nothing, perhaps increases octane lost, but stale gas or water in it, isn't going to go away making a cocktail of 50/50. Just wanted to complain about that myth many fall into.
blunt is offline
post #3 of 9 Old 03-23-2014, 5:01 AM Thread Starter
What's the best way to drain the tank?
Adam_W is offline
post #4 of 9 Old 03-23-2014, 11:23 AM
Quoted: 120 Post(s)
Reputation Power: 198
^ Tilt the tank up, and use a siphon hose to get into the very bottom of the tank.
You might have a bad fuel pressure regulator also. I would be highly suspect of that.
jondog9 is offline
post #5 of 9 Old 03-23-2014, 11:49 AM
You want to remove the petcock, and check the screen, and get any debris out that settles down around it. Put in a little fresh fuel and rinse it out while you're at it. I went on reserve on more than one bike and picked up garbage from the bottom of the tank into my carbs. A fuel filter is a good idea too when you have the tank off, especially on older bikes. Why they don't come with inline fuel filters from the factory is a mystery to me.
blunt is offline
post #6 of 9 Old 03-23-2014, 6:31 PM
Quoted: 120 Post(s)
They do have an inline filter, it's right next to the pump inside the tank.
Probably no petcock or reserve either.
jondog9 is offline
post #7 of 9 Old 03-23-2014, 6:46 PM
Ah. Brain stuck on carbs from another thread.
blunt is offline
post #8 of 9 Old 03-30-2014, 6:20 PM Thread Starter
Well it probably wasn't the cheapest way to fix it but it appears to have worked.
Replaced all the spark plugs and stick coils, then siphoned out as much fuel as I could and added fresh, short test run went well so hopefully that's the last of the issues.
Adam_W is offline
post #9 of 9 Old 03-30-2014, 6:26 PM
Quoted: 120 Post(s)
Fingers crossed...
jondog9 is offline
Running rough ricky13 General Discussion 2 09-15-2013 2:56 PM
cbr running rough cbr 400 Honda CBR400RR 7 11-08-2010 8:13 AM
Running Rough blackpool ben Honda FireBlade 6 06-08-2007 4:13 AM
need help - 954 running rough wayfastwhitey General Discussion 1 12-16-2006 9:15 AM
