2002 CBR 954 Hesitate and dies - Honda Motorcycles - FireBlades.org
post #1 of 21 Old 03-22-2014, 9:14 PM Thread Starter
i have a 2002 Honda Cbr 954 with the following issue when starting and idling after short time will start going in and out with hesitation .. like rpms will go up and down then it will eventually die .. When riding the bike it will have the same issue it will jump rpm down then back up .. and then die and not start for like 10-15 mins ..
i emptied the fuel tank and reinstalled more gas same issue there
i checked the fuel pressure regulator and no leaks or gas coming out into the vacuum ..
i dont understand what it could be just started doing it please help
wayway618 is offline
post #2 of 21 Old 03-22-2014, 9:41 PM Thread Starter
Re: 2002 CBR 954 Hesitate and dies
[IMG]<iframe width="560" height="315" src="//www.youtube.com/embed/VAQRrnOyI1g" frameborder="0" allowfullscreen></iframe>[/IMG]
post #3 of 21 Old 03-22-2014, 9:42 PM Thread Starter
this is the link to the video i have made of it
post #4 of 21 Old 03-22-2014, 9:48 PM
How many miles on your bike? Valves too tight perhaps? As the engine warms up, it becomes tighter, and simply won't get enough air to run. Check your valve clearance. If it's outside of spec, it's a pain to adjust, time consuming anyway. It takes shims, ($75 kit) and you'll have to remove the cams to do the job.
blunt is offline
post #5 of 21 Old 03-22-2014, 9:54 PM
20k miles in the video, when was the last time you replaced / checked the plugs too?
blunt is offline
post #6 of 21 Old 03-22-2014, 10:11 PM Thread Starter
Blunt ...It's been about 2 years since new plugs where installed .. and the valves were done then as well .. As the previous owner states .. which is crazy cause I bought this bike test rode it and had no issues of this until I hit the interstate then it all started .. yesterday .. I can buy new plugs tomorrow and try that as well all the info will be greatly appreciated..
post #7 of 21 Old 03-22-2014, 10:57 PM
You have a way to check for codes, follow steps in a shop manual? This is a V-Tec engine, doing some online searches for similar issues, you did go to the usual places others started at, problem is people never write in the threads later when they solved the issue. "One way street" with a lot of new members asking for help, but won't document success for the next guy. Good time to change that here though.
blunt is offline
post #8 of 21 Old 03-23-2014, 10:30 AM
looks like electrical problem to me going by the video but im no expert maybe something overheating
just the way it blips so quickly not like its fuel etc
sparky68 is offline
post #9 of 21 Old 03-23-2014, 11:28 AM Thread Starter
i guess i can check all the wires make sure no short .. it just seems like when it warms up it does it on idle and riding.. it just wants to like shut down fuel to it then kick back on.. what about fuel relay or something like that getting hot
post #10 of 21 Old 03-23-2014, 12:18 PM
Sounds like you're ready to just tow it into a repair shop that knows what they're doing, and it seems you're doing nothing. Forums just don't have a crystal ball for diagnostics and you sound like you don't know how to fix it yourself, which is common all over this forum. It's the obvious answer, sorry if it ruffles the ego feathers, but you won't find any shorts. Let us know what they did to fix it.
blunt is offline
post #11 of 21 Old 03-23-2014, 12:35 PM Thread Starter
blunt I've done many things so far .. changed gas .. empty tank.. replaced the plugs checked the fpr and now someone said check electrical .. i mean I'm no bike expert but I'm trying here and i did read through every forum and no one has my issues yet why I'm here and even made a video to see if someone else could help point answers ..
post #12 of 21 Old 03-23-2014, 1:06 PM
I did have different problem but FPR seems to be problem even it didn`t leak.
I replace FPR and now bike seems to run much better.
So your problem could also be FPR even it doesn`t leak !
samba2 is offline
post #13 of 21 Old 03-23-2014, 1:24 PM
I understand the desire to save money, satisfaction of fixing your own bike, but going on every whim and direction feed through a forum of what it could be, will actually work against you in this particular situation. I would just take it in. Random parts replacement gets expensive.
blunt is offline
post #14 of 21 Old 03-24-2014, 8:33 AM
I would try getting a volt metre on the fuel pump and make sure it runs continuously. If it's cutting out, this could be the cause. But it will also eliminate a possible culprit.
If you hold the revs up at 3000, does it still do the same thing?
Bluevitz_RS is offline
post #15 of 21 Old 03-24-2014, 11:28 AM
Quoted: 29 Post(s)
Reputation Power: 12
Coil/s? They can break down, worse when hot. I'm sure there is a way to test them with a multimeter/fluke.
Spaz is offline
First post, need help, odd condition that i hesitate to call a "no start" Dusten Honda CBR 600 2 06-12-2008 10:17 PM
DIES ezcustoms Honda CBR 600 4 04-17-2007 11:01 AM
Wax Off - Pat Morita dies at age 73 ConqSoft Off-Topic 11 11-28-2005 10:43 AM
Mr Honda dies ratter Off-Topic 12 07-22-2003 11:34 AM
