1 HID Bulb Flickers and Goes Out 929 - Honda Motorcycles - FireBlades.org
post #1 of 6 Old 03-28-2014, 6:47 PM Thread Starter
Reputation Power: 11
I installed an HID kit, everything seems to be wired correctly. The angel/demon eyes work and they are running off the of same ground that the bulbs run off of. My problem is my right bulb flickers at startup and then shuts off. Both ballast and bulbs are good, tested them both. I get 11.16 volts from the plug that goes into the ballast on both sides. Both sides give me 10.xx volts on start up then settle around the 11.16. Considering the plug to the right side bulb has teh same output as the working side bulb I cannot figure out the problem. My kit came with a H/L relay, but do I need another relay for a 929? I saw somethign else called cancellers that are for daytime running lights. Would either of these solve my problem, or is it somehow bad wiring?
Thanks
01 929
socci is offline
post #2 of 6 Old 03-28-2014, 7:47 PM
Re: 1 HID Bulb Flickers and Goes Out 929
Id put it down to a bad earth. Try running independent earths for each light
fat_lip is offline
post #3 of 6 Old 03-29-2014, 2:34 AM
Quoted: 129 Post(s)
Reputation Power: 66
Is this a constant thing or intermittent? I have low beam HID on mine (single ballast, single bulb) for now and it will sometimes give a small buzz at key-on and not fire off. Not sure if it is the same problem as yours, but mine has something to do with the starter-switch (push to start button) that occasionally triggers as if I were starting the bike. A jiggle sometimes works, if not I restart completely and it fires up.
RRDemon is offline
post #4 of 6 Old 03-29-2014, 9:57 AM
This is with your bike off I hope, as 11.16V is pretty darn low.
Bluevitz_RS is offline
post #5 of 6 Old 03-29-2014, 6:16 PM Thread Starter
Yea the bike was off. It might have been 11.66, I wasnt positive when I wrote that.
That fixed the problem. I appreciate the help. I just assumed the grounds were good since both bulbs used the same ground and one worked.
It was constant. Both bulbs worked for a few cycles, then once I zip tied everything together the right side bulb would just flicker a few times and they die every time.
The lights look awesome now that they are working. I painted my housing black and retro fitted 2 3 inch projectors with white angel and blue demon eyes. I wont have any pictures until I put the bike back together but the blue demon eyes look great. I wired a switch in to shut off my low beams which allows me to just run the eyes during the day. The eyes seemed like they are still going to be bright in direct sunlight.
Fender isnt buttoned up at all, but I just wanted to get an idea.
01 929
socci is offline
post #6 of 6 Old 03-30-2014, 1:32 AM
Quoted: 129 Post(s)
Glad it only turned out to be a ground! I do love the look of the projectors. There's a company that does a lot of headlight work on an exchange basis (I think KT cycle... JT....erm yeah something). I've been considering this as a mod for my 54.. just haven't decided to take the leap since I still want to sort the suspension all the way and get a good set of rear sets before I dive into any cosmetics.... so far everything (I think) has been functional =) I did the low-beam HID too as it was much brighter and nicer at night.
RRDemon is offline
what bulb? Westy Honda CBR400RR 9 09-21-2013 8:14 PM
93 CBR900RR Temp needle flickers Tac2cul Honda FireBlade 5 04-04-2013 6:32 PM
Tempature light flickers Scottys72 Honda Cruisers 1 05-22-2012 7:58 PM
Bulb size KBROCK14 Honda FireBlade 4 04-02-2010 12:36 AM
954 FRONT FLUSH MOUNT FLICKERS NICE954 General Discussion 0 09-11-2008 4:25 AM
