929 won't run - Honda Motorcycles - FireBlades.org
post #1 of 11 Old 05-06-2014, 9:14 PM Thread Starter
929 won't run
Hello I have a 2000 929 that I'm working on , it ran before winter , someone cut the kill switch wires and the ignition wires , I fixed all the wires I found cut , all the switches are working but the fuel pump will not turn on , tested pump and it works , tested computer in another bike and it works , changed all relays , checked and changed lean sensor , changed all four wire harnesses and gauges , checked all fuses and grounds and still nothing , I did not change stator , rectifier , crank or cam sensors , I'm stumped / lost please help
javan1 is offline
post #2 of 11 Old 05-06-2014, 9:26 PM
Quoted: 58 Post(s)
Re: 929 won't run
I'm not familiar with that bike in particular but did you check your safety switches such as the kick stand?
Sabotage is offline
post #3 of 11 Old 05-06-2014, 9:39 PM
Re: 929 won't run
Check for 9 volts on the pink wire at the ignition switch (key switch)
2001 Erion 929 Race Bike
1998 Ducati 748
2002 CR125/CR500 Aluminum Conversion
1994 CR500 Completely Built
2000CR250/CR500 Conversion In Process
1950 Indian Warrior 500cc Vertical Twin
1995 Mustang Cobra Turbo Built 820rwhp/879ftlbs
zfrilly3 is offline
post #4 of 11 Old 05-06-2014, 10:04 PM Thread Starter
Re: 929 won't run
I have checked safety switches .
I have tried 3 ignitions one of witch was brand new and didn't make any difference , I will check the voltage next time I work on it .
javan1 is offline
post #5 of 11 Old 05-09-2014, 8:14 AM Thread Starter
Re: 929 won't run
Any more help please
javan1 is offline
post #6 of 11 Old 05-09-2014, 9:49 AM
Re: 929 won't run
Do you have spark?
Not throwing any MIL on the dash?
Tried bypassing the kill switch?
post #7 of 11 Old 05-09-2014, 2:18 PM Thread Starter
Re: 929 won't run
Coils and injectors have power , won't fire at all , injectors won't fire ether with pump hit wired , kill switch has Ben checked ( all wires have power when it's on ) , no codes
javan1 is offline
post #8 of 11 Old 05-09-2014, 6:21 PM
Re: 929 won't run
How many volts on the pink wire coming from the key switch? Not "it has power", need to know the voltage
1998 Ducati 748
zfrilly3 is offline
post #9 of 11 Old 05-09-2014, 7:20 PM Thread Starter
Re: 929 won't run
I don't know the voltage yet I haven't been back to the guys house to work on it again , I'm trying to get a few thing to look at b4 I go back , what is the 9v for ?
javan1 is offline
post #10 of 11 Old 05-09-2014, 8:51 PM
Re: 929 won't run
tells the computer its ok to turn on fuel pump. until you get that working without being jumped you should go no further.
1998 Ducati 748
zfrilly3 is offline
post #11 of 11 Old 05-10-2014, 1:10 AM Thread Starter
Re: 929 won't run
It was the ignition switch even the new one was bad took mine out of the 954 it in and everything works , thanks everyone for all the help
javan1 is offline
