99 CBR 900RR - Gas in Tailpipe then Oil in Tailpipe - Honda Motorcycles - FireBlades.org
post #1 of 9 Old 05-12-2014, 6:55 PM Thread Starter
CJL
Can anyone help? My bike was stored for a while and when I got it out and gassed it up, one of the carbs filled with gas. after I thought that was taken care of it then sput oil and smoke out the tailpipe. I would like to get you guys opinions before I take it to the shop. I read online that the float valve would cause the gas issue, but what about the oil? Thanks in advance for your help.
CJL is offline
post #2 of 9 Old 05-13-2014, 12:54 AM
Reputation Power: 36
Re: 99 CBR 900RR - Gas in Tailpipe then Oil in Tailpipe
Maybe the gas from flooding carb did fill the crankcase full of gas/oil. Then when you crank it crankcase pressure blew it in air box and cycled it thru to exhaust.
Is your crankcase overfull?
Airbox got oilly stuff sprayed in it?
Rubber side down, One wheel to the sky for those who we won't forget. R.I.P homies miss you.
900rrHonda is offline
post #3 of 9 Old 05-13-2014, 1:46 AM
The fuel would've filled the crankcase as well, and the diluted oil would then come through the exhaust system.
If you have a vacuum-operated fuel tap, check the vacuum hose is not sucking fuel.
As already mentioned, check your oil.
post #4 of 9 Old 05-13-2014, 4:03 AM
Quoted: 159 Post(s)
Reputation Power: 122
Happened to me on a dirt bike someone borrowed, then stored. They left the pet-cock on, (dumb-a**). When I went to ride it a month later I found the cylinder/crankcase full of fuel.
fj1200rj is offline
post #5 of 9 Old 05-13-2014, 6:22 AM Thread Starter
CJL
Yes, the gas/oil was all in the air filter area.....how do I stop it? Thanks everyone for all the feedback....
CJL is offline
post #6 of 9 Old 05-13-2014, 8:22 AM
Replace engine oil with new to correct level.
Fix float overfilling.
Then gas her up and run it.
She gonna smoke for a bit but itll clear out.
post #7 of 9 Old 05-13-2014, 2:42 PM
Quoted: 159 Post(s)
Like 900 said oil and filter. Run it, ride it to clean her out. When you get back, disconnect the fuel line and see if the petcock is leaking, fix the petcock and figure out which needle/seat is leaking also. You already ran it so it's too late to pull the plugs and pump it out of the cylinders to avoid hydrolock, but if (hopefully not) there's a next time...
fj1200rj is offline
post #8 of 9 Old 05-19-2014, 9:41 AM Thread Starter
CJL
Thanks again guys, I did all that, had two floats stuck open....cleaned up everything. I now have a problem with idling. Seems like she is trying to run okay, but still a rough idle...will not idle unless choke is on. Do I just need to ride her out????
CJL is offline
post #9 of 9 Old 05-19-2014, 9:44 AM
You need to strip the carbs and clean the pilot circuits out.
Ohlins HO802 Shock off 97 900RR on my 94 900RR, Any Fitting Concerns devildog4evr General Discussion 14 07-08-2013 6:57 PM
Can I put a 1999 Cbr 900rr motor on a 1995 cbr 900rr frame? megan_miler707 Honda FireBlade 5 08-13-2012 10:42 PM
94-97 900RR Headlight Cover Close To Fitting 93 900RR? Caccam Honda FireBlade 0 08-04-2012 9:01 PM
1999 cbr 900rr Ohlins Rear shock to fit 1997 cbr 900rr? BladeNewbie Aftermarket Perfomance Parts Reviews 0 09-20-2011 5:53 PM
Can I put a 1999 Cbr 900rr motor on a 1995 cbr 900rr frame? megan_miler707 General Discussion 2 05-21-2009 10:14 PM
