93 900rr neutral switch question - Honda Motorcycles - FireBlades.org
post #1 of 7 Old 05-12-2014, 8:46 PM Thread Starter
Hey guys I'll try and put some pictures.. I found a broken wire it's the middle wire coming out of this plug with 3 wires and I'm wondering if it is for the neutral switch since my bike will only crank with the kickstand up but doesn't spark when it does, and my neutral light doesn't light up.. Thanks for any help!
Benzcreww is offline
post #2 of 7 Old 05-12-2014, 8:50 PM Thread Starter
Re: 93 900rr neutral switch question
Also if anyone could tell me where this wire should go to that'd be awesome
Or if I should try to ground it
post #3 of 7 Old 05-13-2014, 4:02 AM
Quoted: 660 Post(s)
Reputation Power: 102
The middle wire should be the neutral switch. It goes from the switch to the connector to the ECU. Is it broken between the switch and connector? Or Connector and ECU? The second picture is upside down. The neutral switch is on the lower engine case on the left side.
IanDoohan is offline
post #4 of 7 Old 05-13-2014, 3:43 PM Thread Starter
I got a better look and the wire going to this is ripped and I guess I need a plug for it
post #5 of 7 Old 05-13-2014, 4:33 PM Thread Starter
Connected the wire to it, neutral switch works fine still no spark though
post #6 of 7 Old 05-13-2014, 5:26 PM
Is the clutch switch working?
post #7 of 7 Old 05-13-2014, 6:06 PM Thread Starter
Not sure, how do I check it? Thanks
Fuel lines and neutral switch tyson690 Honda FireBlade 9 06-08-2016 12:43 PM
Neutral switch woes Keithy Honda CBR400RR 10 02-25-2014 7:57 PM
Neutral Switch Issues - 97 CBR900 Tupp Honda FireBlade 13 04-15-2013 3:00 PM
neutral light 900RR Taargus_Taargus General Discussion 1 03-19-2013 12:32 AM
neutral safety switch??? cody5127 New Rider Orientation 4 08-09-2012 11:39 PM
