929 Clutch problem? - Honda Motorcycles - FireBlades.org
post #1 of 2 Old 06-09-2014, 2:53 PM Thread Starter
929 Clutch problem?
Hello!
I've put my 929 motorcycle on the stander(back wheel), pulled the clutch all the way and switched 1'st gear. The problem is that the back wheel starts to spin pretty fast. Is it normal? Shouldn't the clutch fully disengage? I had adjusted the slack in the cluch lever(10-20 mm) but it's the same. Since i've just replaced the engine i''m worried that this will affect other parts of the engine.
1. Should i worry?
2. Should i replace anything?
No other bad symptoms.
marian.herciu is offline
post #2 of 2 Old 06-09-2014, 3:51 PM
Re: 929 Clutch problem?
Originally Posted by marian.herciu View Post
Hello!
1. Should i worry?
The wheel should slow down as the oil heats up, but some drag is normal.
Unless the bike is actually pulling forward when you put it into gear then it's nothing to worry about.
Clutch problem? navuku Honda FireBlade 2 08-25-2013 5:10 PM
Clutch Problem.? Sfighter900 Honda FireBlade 9 12-14-2011 12:52 PM
2009 HRC Clutch or clutch cable problem?? floppy Honda FireBlade 13 09-15-2009 7:00 AM
f3 clutch problem bigkeyz Honda CBR 600 12 07-04-2009 3:21 PM
clutch problem jon 8214 Honda FireBlade 6 02-20-2007 7:07 PM
