929 Rear Shock question - Revalve or replace? - Honda Motorcycles - FireBlades.org
post #1 of 4 Old 06-13-2014, 9:51 AM Thread Starter
Reputation Power: 9
One day I'll be employed again, and I can actually work on my 929. For now it doesn't cost me anything to ogle parts...
So, from what I gather, the stock 929 shock isn't very good. I've narrowed it down to a couple of options:
1) Do a RaceTech re-valve and re-spring; or
2) Buy a Penske 8983
The most cost effective route would be to go RaceTech. My concern with that is even though a new piston/valving and spring would help loads, would I still be limited by the stock shock's adjust-ability? Online research has mentioned that the stock clickers don't do much of anything when making changes on compression and rebound.
FWIW, I'd be doing the front also.
2000 CBR929RR
MikeG929 is offline
post #2 of 4 Old 06-13-2014, 9:55 AM
Re: 929 Rear Shock question - Revalve or replace?
I don't agree that the OEM shock is rubbish, mine's just fine.
Are you actually finding the shock to be falling short in performance?
post #3 of 4 Old 06-13-2014, 10:04 AM Thread Starter
Reputation Power: 9
Not so much falling short, just want to make it more "me", you know?
I suppose I should spend some proper time setting it up, but shiny things and all.
2000 CBR929RR
MikeG929 is offline
post #4 of 4 Old 06-13-2014, 9:36 PM
Reputation Power: 31
I gave a member in Fremont Ca. (Madamosa or something like that) a stock shock with 0 miles on it. Try to track him down and see if he used it. Nothing like the Ohlins I put on but send it to RaceTeck and see what they can do.
ERION929 is offline
Rear shock rebuild or replace bladderwax General Discussion 5 08-11-2009 9:10 PM
anyone do a Racetech spring and revalve on a 954 shock? RCW Honda FireBlade 5 02-22-2007 5:58 AM
Rear Shock Question - F4i cvc14 Honda CBR 600 2 08-15-2006 5:36 AM
Rear Shock Revalve for the PROS? - READ THIS Tank69 Honda FireBlade 2 09-25-2003 2:00 AM
Stock shock rebuild/revalve Voodoo954 Honda FireBlade 3 09-24-2003 9:21 AM
