1994 Honda CBR 900 start up problems. - Honda Motorcycles - FireBlades.org
post #1 of 3 Old 06-13-2014, 9:57 PM Thread Starter
Hello all!
I've recently had some electrical problems with my 1994 Honda CBR 900.
Some background information:
Was at an intersection one day and my CBR stalled out on me (embarrassing). As I went to start it up, the engine wouldn't turn over, but the lights turned on. Had the battery jump started and it turned right on. Thought it was strange for the battery to die on me when the engine was just on... Got home and checked the voltage and noticed that the alternator was only pumping 12 volts into the battery, when it should be between 13 and 15. Opened up the Rectifier Regulator and found that the wires leading into it were burnt to a crisp (Not sure if this was the cause).
To make a long story short, we replaced the burnt wire clips with new ones and put a brand new plastic adapter in place of the old one as well.
Now she wont start at all. No lights, no turnover. Jump start wont even work.
Note: It did start with the old burnt wires prior to installation.
If anyone could help me identify what could be the problem, it would be greatly appreciated!!!!!!
mlosacco is offline
post #2 of 3 Old 06-14-2014, 10:24 AM
Quoted: 660 Post(s)
Reputation Power: 102
Re: 1994 Honda CBR 900 start up problems.
Originally Posted by mlosacco View Post
Hello all!
Sounds like your typical stator overcharging and reg/rec issues. I know it's gonna sound dumb, but did you make sure you have the wires in the replaced connector in the right spot? There are countless threads dealing with this issue. I think the red/white wire comes from the main fuse, but I would have to check the wire diagram. Make sure the 30 amp main is still good at the starter solenoid.
IanDoohan is offline
post #3 of 3 Old 06-15-2014, 8:48 PM
Throw that POS R/R away. Mine left me stranded 2 hours from home. Get one from a 04-05 GSXR and wire it in.
I fix bikes and write about them here. I wouldn't read it if I were you, you will probably regret it.
http://oneguytwowheels.blogspot.com/
GarrettSR5 is offline
1994 CBR 900RR Wont Start sens19 Honda FireBlade 11 03-19-2013 1:00 AM
For Sale:1994 Honda VFR 750 aaronb Motorcycles For Sale 1 03-14-2010 11:43 PM
1994 HONDA CBR 600F2 jamesfs912 Motorcycles For Sale 0 02-01-2010 9:07 PM
$3,500 1994 Honda CBR 900RR kailibug07 Motorcycles For Sale 5 10-31-2009 4:52 AM
Help! Honda CBR 600 F3 ; starting problems , won't start 17% Honda CBR 600 7 09-21-2008 9:48 PM
