929 won't start - Honda Motorcycles - FireBlades.org
post #1 of 4 Old 06-29-2014, 11:44 AM Thread Starter
929 won't start
So I was having an issue with my bike getting hot & ordered a new fan temp switch put it on and still fan would only turn on at 230. I decided to add a manual fan switch I could flip on when needed, bought a simple switch and wire and wired from fan switch to negative batt terminal, success it worked. Put eveything back and now bike won't wont start. I hear a click as it trys, fuses seem to be ok, anyone have any ideas? Also bike was running fine an hour before me adding switch and I've disconnected switch wires.
rudy929 is offline
post #2 of 4 Old 06-29-2014, 10:46 PM
Re: 929 won't start
What do you mean you hear a click "as it tries"?
Is the battery charged?
Pump priming okay?
No codes on the dash?
post #3 of 4 Old 06-29-2014, 11:19 PM Thread Starter
Re: 929 won't start
Battery is charged fuel pump does prime f1liht was always on but previous owner said it was the aftermarket eexhaust and bike ran fine up until I set the manual fan switch. I believe I shorted someting as I grounded to negative battery terminal. The click is just a simple click as I let off the start button it tries to start doesn't and a simple click at the end of said process.
rudy929 is offline
post #4 of 4 Old 06-30-2014, 5:33 AM Thread Starter
Re: 929 won't start
Any ideas on what I could have shorted by grounding manual fan switch directly to negative battery terminal I ran it from temp sensor on radiator, bike tries to start but doesn't any fuses or relays I should check.
rudy929 is offline
09 Cbr1000 tried to start by itself. Now won't start. anti_everything General Discussion 9 05-20-2012 10:33 AM
cant start, wont start shanelufc Honda CBR400RR 3 01-28-2011 2:44 AM
1999 Fireblade hard start, now wont start.... MFB_87 Honda FireBlade 15 03-18-2010 11:58 PM
'00 F4 - Won't Start, where do i start? cranks but doesnt fire. dunkd Honda CBR 600 7 07-30-2007 5:32 PM
cold start(how does your 954 start) JakeT Honda FireBlade 21 06-28-2005 11:01 PM
