929 rry spluttering 4500rpm - Honda Motorcycles - FireBlades.org
post #1 of 11 Old 06-30-2014, 4:01 PM Thread Starter
Quoted: 3 Post(s)
Reputation Power: 7
bike spluttering at 4500 rpm. Have changed fuel tank/pump throttle bodies/injectors. plugs, wireing harness, ecu, hiss, generator, cam sensor, sidestand switch, spark pickup,removed exhaust valve. totally stuck has anybody any ideas.
dave600rr is offline
post #2 of 11 Old 06-30-2014, 8:29 PM
Re: 929 rry spluttering 4500rpm
It does this regardless of gear or throttle position?
You didn't mention the fuel pressure regulator - have you checked it?
post #3 of 11 Old 07-01-2014, 4:23 PM Thread Starter
Quoted: 3 Post(s)
Reputation Power: 7
Spluttering in any gear or throttle position. Fuel pressure pump was changed with throttle bodies/injectors etc.
post #4 of 11 Old 07-03-2014, 2:36 PM
RTJ
Check your air filter?
RTJ is offline
post #5 of 11 Old 07-03-2014, 3:53 PM Thread Starter
Quoted: 3 Post(s)
Reputation Power: 7
New k/n fitted
post #6 of 11 Old 07-03-2014, 8:57 PM
New k/n fitted
It wasn't a problem before you fitted the K&N though?
post #7 of 11 Old 07-04-2014, 3:00 PM Thread Starter
Quoted: 3 Post(s)
Reputation Power: 7
Not sure bike was bought in winter exhaust changed power commander and k/n filter fitted
Then bike set up on dyno then parked in shed for rest of winter. Have changed exhaust and tried bike with power commander disconnected.still the same
post #8 of 11 Old 07-05-2014, 6:54 PM
Reputation Power: 9
Is the exhaust valve still connected and working properly?
livinloud11 is offline
post #9 of 11 Old 07-06-2014, 1:25 AM Thread Starter
Quoted: 3 Post(s)
Reputation Power: 7
exhaust valve removed and plug fitted to stop warning lights coming on
post #10 of 11 Old 07-11-2014, 3:05 PM Thread Starter
Quoted: 3 Post(s)
Reputation Power: 7
Bike was checked on dyno and found Spluttering was caused by overfueling. Have run out of ideas so engine is going to be replaced.
post #11 of 11 Old 07-11-2014, 10:02 PM
How is replacing the engine going to affect the fueling?
CBR400 RRJ spluttering & overfuelling fireblade4444 Honda CBR400RR 6 11-15-2014 5:56 AM
929 spluttering/missing dave600rr Honda FireBlade 2 04-08-2013 10:22 AM
95 CBR900rr spluttering when cold Kav Honda FireBlade 5 10-17-2011 4:10 PM
Spluttering... CBR400_Paul Honda CBR400RR 8 07-09-2009 7:50 AM
Sluggish under 4500RPM mattz400 General Discussion 11 09-23-2008 5:40 PM
