2001 CBR929rr fuel pump relay won't click - Honda Motorcycles - FireBlades.org
post #1 of 7 Old 07-03-2014, 8:01 PM Thread Starter
I made a post about two weeks ago about my bike not running right because my stator and rectifier were fried, i replace them both and today i go to start the bike and now my fuel pump relay won't click. I checked the hot wire from the relay harness and hot wired it from my battery and my pump primed, but when I put the relay on and turn the bike on it won't click at all. I tried testing the relay with a multimeter but it will not complete a circuit. This means the relay is bad? I can't seem to find them anywhere.
Tvair450 is offline
post #2 of 7 Old 07-04-2014, 12:57 AM
Re: 2001 CBR929rr fuel pump relay won't click
use your headlight relay in front of the speedo to replace the relay in question. if your bike runs when you use the other (headlight) relay go buy a new relay... beware they're like $39.00 at the dealer.
GT00 is offline
post #3 of 7 Old 07-04-2014, 1:22 AM Thread Starter
That's a splendid idea. I wonder if my battery is too weak? I'll put another battery in and see if that has higher volts, when my stator and recti went my battery probably did as well. If that doesn't work I'll replace the relay like you suggested and see if I can get it to throw some codes if it doesn't work. It took me a while to find that relay online, but on ebay I can find them cheap, i called all the dealers around me and not one in stock.
Tvair450 is offline
post #4 of 7 Old 07-04-2014, 2:13 AM
No, it means you don't have power going to the relay.
post #5 of 7 Old 07-04-2014, 2:15 AM
Try jumper leads to boost it from another battery, but I doubt it's the battery if it runs the pump when you bypass the relay. You need to get power to the relay. Have you tried bypassing the kiilswitch?
post #6 of 7 Old 07-04-2014, 11:18 PM Thread Starter
FIXED. My BAS was tripped and had to disconnect it and reconnect and the bike runs flawlessly now. Should have been the first thing I should have checked.... hahaha
Tvair450 is offline
post #7 of 7 Old 07-05-2014, 12:25 AM
The BAS doesn't "trip" though, it just cuts the fuel and ignition. All that is required to "reset" it is to cycle the ignition.
I would guess the connector was loose or dirty.
2001 CBR929rr fuel pump won't prime Tvair450 General Discussion 22 06-26-2014 6:56 PM
Fuel pump relay 04 RC Gariepy Honda RC51 1 09-20-2011 9:05 PM
Fuel pump relay Blakey0078 Honda RC51 0 05-27-2010 4:50 AM
Help need, Fuel pump relay cbr900cycle Honda RC51 0 02-11-2008 11:57 AM
929 FUEL PUMP RELAY?? CHAR929 Honda FireBlade 3 05-24-2007 8:01 PM
