2009 Honda CBR1000RA ABS Problem - Honda Motorcycles - FireBlades.org
 2Likes
post #1 of 35 Old 07-29-2014, 1:14 PM Thread Starter
I have an intermittent problem with the ABS on my 2009 CBR1000RA. I've owned the bike since it was new, it has 12000 miles on it. The problem started this year. Sometimes after riding 50 miles or so I get the fast flashing LED that indicates an ABS failure. After the failure, once I put the ABS in diagnostic mode, I get a diagnostic trouble code of either 5-1 or 5-3, most often 5-3. According to the shop manual this indicates a problem with the front power unit or air bleeding incompletion. As per the procedure, I did the normal front brake line bleeding. Since there was air in the system I figured that would resolve the problem. I reset the diagnostic trouble code, and once again I rode it for 50 miles or so before there was a failure. Next I tried bleeding part of the ABS system as per the instructions in the manual, I didn't do all of it yet because it requires removing the radiator, etc. This also cured the problem for a couple of days, about 100 miles or so. Before I tear it all apart, I thought I'd see if anyone on the forum has had a similar problem with their ABS and what it took to fix it. Any and all suggestions are welcome. Thanks for your help.
rcs103062 is offline
post #2 of 35 Old 07-29-2014, 1:25 PM
Re: 2009 Honda CBR1000RA ABS Problem
Problems with the ABS are not rare - I believe a member here had complete loss of brakes on his 1000RR. Have you had a dealer look at it?
post #3 of 35 Old 07-29-2014, 1:31 PM Thread Starter
No, I haven't had a dealer look at it yet.
post #4 of 35 Old 09-29-2014, 7:29 PM
I am having the exact same problem with my 2009 CBR100RA that you describe in your post. One dealership wanted $2400 to replace the front ABS power unit! Another wants $450 to "properly bleed the brakes". I've already had this done once and only temporarily fixes the issue. Have you had any luck getting this issue resolved?
garycb is offline
post #5 of 35 Old 09-29-2014, 9:00 PM
I've seen this covered in some 22 pages of steps and conditions to do it, have fun.
http://www.expandingknowledge.com/Je...r_Bleeding.pdf
blunt is offline
post #6 of 35 Old 09-30-2014, 2:05 PM Thread Starter
I don't know if you're mechanically inclined or not but bleeding the brakes myself helped with the problem for a while. I just did the standard part of the bleeding and kept getting air out of the system every time I did it. Doing the whole bleeding procedure requires taking apart a lot of the bike. I wouldn't try to do it unless you have the manual. I guess that's why the dealer charged so much for it.
Thanks for letting me know that was only a temporary fix in your case too. I'm still working on the problem, I don't want to pay $760.00 for a power unit unless I'm sure that will fix it.
FYI, if you remove the fuse for the ABS, the brakes operate as standard brakes. The ABS is fail-safe. The only issue with that is the ABS light stays on all the time, but at least it's not flashing.
I checked with the dealer to see if there were any service bulletins on the ABS, and naturally he said no. My main complaint is that the ABS was a $1000 option, but any single component in the system is almost $1000. I would never have bought the CBR with the ABS if I had known that it would be so difficult to work on.
Thanks for taking the time to reply. As you can see, I haven't received much feedback on the problem.
post #7 of 35 Old 10-01-2014, 8:30 PM
I agree, I would never have paid for this safety feature if I knew it would be such a pain!
I'm not going to take the bike apart unless it becomes apparent the front ABS unit is at fault. I will try the basic brake bleeding to see if it helps. Thanks for the tip about the fuse.
The dealership I went to called Honda about the problem and the response was that they had never heard of this issue...yeah right.
Good luck, I'll post if anything changes.
garycb is offline
post #8 of 35 Old 10-01-2014, 8:51 PM Thread Starter
One last question, do you know the fault code you are getting when the ABS fails? I'll let you know if I figure anything else out.
post #9 of 35 Old 10-02-2014, 10:55 AM
5-3
Restarting does not clear the fault, but letting the bike sit overnight does!
Heat related?
garycb is offline
post #10 of 35 Old 10-02-2014, 8:45 PM Thread Starter
Yes, I've wondered about that too. Sometimes just sitting overnight cures it, others it does not. I've noticed that whenever it's cold out it will sometimes last for a 75 mile ride. I think we have the exact same problem. Seems like a design problem to me.
The manual also says that the 5-3 code can be caused by a front brake caliper piston malfunction. I haven't looked at that yet either.
Thanks,
Bob
post #11 of 35 Old 07-01-2019, 9:01 AM
Quoted: 2 Post(s)
Hi, I have the same problem. I got the bike with 45000 km on. The previous owner never serviced the brake fluid as he said that it was too complicated. The problem happens only after the bike gets hot and you use the brakes for a while. It never happens when the bike is cold. To me, it is a heat problem, somewhere in the valve or the power unit. Do you know if a complete brake fluid change and bleeding solves the issue, at least for some months, before heat deteriorates the fluid?
Savvas C is offline
post #12 of 35 Old 07-01-2019, 9:16 AM
Quoted: 2 Post(s)
Hi I have the same problem. It happens only after the bike gets hot and you use the brakes for a while. It never happens when the bike is cold. To me, it is a heat problem, somewhere in the valve or the power unit. I will do a complete brake fluid change and bleeding and will let you know if the issue persists.
Savvas C is offline
post #13 of 35 Old 07-01-2019, 1:22 PM
nigelrb's Avatar
Quoted: 227 Post(s)
Reputation Power: 7
Send a message via Skype™ to nigelrb
The Honda C-ABS system is over complicated and forums across the world have been plagued with problems by SOME owners. From my knowledge, there has never been a definitive or isolated problem, rather, there has been a range of them.
A PROPER bleed with new fluid should solve it, but bleeding ABS is really a task for a very patient professional or well-equipped DIYer. The dealer charge (UK) is around 300 (don't know your location so I can't convert)
nigelrb is online now
post #14 of 35 Old 07-01-2019, 1:31 PM
Quoted: 2 Post(s)
Dear Nigelrb, thank you for the answer!! I have got the service manual and published instructions by other members. So, I will give it a try for a complete brake fluid change and bleeding, with lots of patience (it appears to be a week of work for somebody who hasn't done it before, like me), and see if it resolves the issue.
nigelrb likes this.
Savvas C is offline
post #15 of 35 Old 10-23-2019, 12:58 PM
Quoted: 6 Post(s)
Just as an FYI, i have purchased two 2009 CBR1000RA bikes in the last 2 years and both of them had the issue with the blinking ABS light. It would only come on when the bike is hot and i hit the front brake repeatedly (especially in stop and go traffic). As others have stated, i always got a combination of the 5-1 and or 5-3 error code. Simply bleeding the normal brake lines at best helped for a day or so.
I have become pretty efficient (as efficient as possible) in bleeding the entire ABS system and do so every 12 month with the OEM Honda DOT4 brake fluid. I believe it's mostly the lines going to the front power unit, as they are nicely located between the super hot exhaust headers and the engine block. Since i have started doing this, i have not had the ABS light come back on, on either of my two bikes. Plus the brakes have a much harder feel to them as a bonus.
FYI, i remove all fairings and then simply use an 8mm socket with two extensions to bleed the front power unit, rather than removing the radiator and exhaust headers. I then put a bit of tin foil over the headers and engine block to avoid the brake fluid touching it. At the end i simply wash everything down with some brake cleaner. The hardest part is removing all the fairings, after that the full bleeding procedure is pretty "simple"
Here is a quick video showing what the bleeding of the front power unit looks like
nigelrb likes this.
sswiss3000 is offline
Tags
5-1 or 5-3 fault code , abs , cbr1000ra , cbr1000rr , problem
CABS Problem 1000RR 2009???? FB1000inPA General Discussion 2 01-29-2014 8:51 AM
2009 CBR1000RA Battery help Effie Honda FireBlade 5 03-19-2011 9:45 PM
CBR 1000RR 2009 ABS PROBLEM-HELP cbrforewer Honda FireBlade 11 02-18-2011 5:21 PM
2009 HRC Honda Fireblade (ENGLAND) - From end of August 2009 GazRR Motorcycles For Sale 17 03-27-2010 11:29 AM
CBR1000RA WSBK Tuned by japanese knightly Honda FireBlade 0 03-01-2007 12:17 PM
