919 initial lose of power when changing gears - Honda Motorcycles - FireBlades.org
post #1 of 14 Old 09-29-2014, 7:51 AM Thread Starter
Hey Guys,
Wondering if any one can help or suggest anything to help me
I have a 99 blade(919) the bike runs like the wind but it has started to develop a miss at mid range almost like its not getting enough fuel then when the revs go above 7000rpm she comes to life again, Almost every-time i shift up or down the bike has a loss in power for a second or 2 and then gets life again. I have taken my can off, if i put the can back on it make no difference.
Mattbeads is offline
post #2 of 14 Old 09-29-2014, 9:52 AM
Re: 919 initial lose of power when changing gears
Did you just change the exhaust?
Sounds like a fuelling related issue.
Bluevitz_RS is offline
post #3 of 14 Old 09-29-2014, 10:40 AM Thread Starter
I Currently have no exhaust on the bike(straight pipe) but even if I bolt the exhaust back on the issue remains the same. I think it is a fuelling issue, i am hoping someone might have had this same issue and can suggest a possible solution.
post #4 of 14 Old 09-29-2014, 11:32 AM
If you pull the choke while it's having the problem, does it go away?
Chances are the bike needs to be re-jetted and is running lean.
post #5 of 14 Old 09-29-2014, 11:48 AM Thread Starter
Initially it did go away when i pulled out the choke yes, i tried it again on the last ride and the choke made no difference. the bike pops like crazy on de-acceleration
post #6 of 14 Old 09-30-2014, 3:54 PM
Popping on decel indicates lean for sure on the idle circuit.
post #7 of 14 Old 10-01-2014, 5:06 AM Thread Starter
Checked Plugs last night and looks very lean, I am going to add a small washer to the mane needle, this addresses the fuel from 1/4 to 3/4 throttle, maybe this will sort out my issues, but for now i noticed my fuel is not shutting off in the carbs and has now leaked into my oil...grrr
post #8 of 14 Old 10-01-2014, 5:22 AM
Quoted: 159 Post(s)
Reputation Power: 122
You need to address the needles/seats leaking while you're in there.
fj1200rj is offline
post #9 of 14 Old 10-01-2014, 5:49 AM Thread Starter
Agreed, i have cleaned and polished the needles and seats a few times already ,very frustrating, might just need to get new ones
post #10 of 14 Old 10-01-2014, 8:53 AM
If the floats are leaking chances are there's dirt on the seat of the needle valve. I'd pull them off and at least take the bowls off and clean everything with carb cleaner. It'll also make it easier to adjust the needle jet.
post #11 of 14 Old 10-01-2014, 10:06 AM Thread Starter
Thanks for the advice, I am so sick of cleaning my carbs already, but just had tank lined so the carbs are pretty much spotless but will take your advice and just clean them out anyway. thanks man
post #12 of 14 Old 10-01-2014, 12:03 PM
Maybe add in a fuel filter if you don't have one.
If you do take them apart, inspect the seats on the needle valves very closely for pitting. If you find any I'd replace them.
post #13 of 14 Old 10-01-2014, 1:50 PM Thread Starter
I am actually running 2 filters at the moment(is this overkill?) i will check the seats out very carefully as you advised...many thanks
post #14 of 14 Old 11-03-2014, 3:53 AM Thread Starter
so turns out that the blade does not like any forced air, i took of the snorkels. I have since added back the snorkels and fixed a few air leaks on the barb boots. much better.
NC23 changing gears issue Rustee55555 Honda CBR400RR 7 05-09-2012 10:19 AM
Initial operating temps keval General Discussion 6 08-29-2009 2:33 PM
Help!!!!!!!!!!!!!!!! problem changing Gears. dpjmusic21 Honda CBR 600 12 04-03-2009 7:19 PM
RC51 POWER LOSE portermd Honda RC51 1 02-12-2007 10:36 AM
Initial D fans... nomad Off-Topic 6 07-21-2003 10:43 AM
