929 won't start-What to check - Honda Motorcycles - FireBlades.org
post #1 of 19 Old 10-12-2014, 7:57 PM Thread Starter
Well, pulled my tank back too far to get to the airbox to replace the air filter and busted the fuel return hose. After sufficiently bathing myself in gasoline I replaced that hose as well as the vent hose to the evap canister (It's a CA model). Now she won't start. Engine is turning over strongly, but just won't start. I can hear the fuel pump when I turn the key on.
Here is what I have done:
-Check all the hoses for kinks, looks OK
-Looked to see if I pulled any wires out when I pulled the tank back too far. Everything looks OK
-Bank angle sensor looks OK
In the interest of full disclosure a couple of other things that were touched since the last time it ran I thought I should mention:
-Removed the O2 sensor and put an O2 sensor eliminator. I put a bolt in the pipe. Should have done this when I installed my power commander III
-Removed the tail section to rewire the tail light/turn signals.
-Replaced the turn signal flash relay with an aftermarket one
-Removed and reinstalled the battery
I'm guessing it's just not getting fuel, but not sure why. What would you check?
davbib is offline
post #2 of 19 Old 10-13-2014, 3:03 AM
Re: 929 won't start-What to check
Any codes on the dash?
Kill switch is on?
post #3 of 19 Old 10-13-2014, 11:34 AM Thread Starter
No codes on the dash. Kill switch? Man, that would be embarrassing. I always leave it on. I'll have to check it when I get home, but the starter is cranking. I don't recall if it will crank with the kill switch off.
Just for Fun, I went home at lunch and the kill switch right where I left it, in the on position. Fuses all look OK and although I did end up draining a lot of gas, my low fuel isn't on. Maybe I'll throw in a gallon of gas just for the heck of it.
Now what?
davbib is offline
post #4 of 19 Old 10-13-2014, 8:28 PM
Quoted: 120 Post(s)
Reputation Power: 198
If you can hear the pump prime, and you checked all your hoses, then are you sure you're getting spark? See if she fires on a little blast of starting fluid?
jondog9 is offline
post #5 of 19 Old 10-13-2014, 8:39 PM Thread Starter
Thanks. I was gonna try that just for kicks. Seems like it would be fuel related since I that is what I messed with but a little starting fluid is an easy check.
davbib is offline
post #6 of 19 Old 10-18-2014, 3:16 PM Thread Starter
Fresh gas, no help. I did get her to fire with some starter fluid, so it's getting a spark and not fuel. Suggestions on what to tackle next?
davbib is offline
post #7 of 19 Old 10-18-2014, 10:23 PM Thread Starter
Bump
davbib is offline
post #8 of 19 Old 11-01-2014, 7:30 PM Thread Starter
OK guys- new pressure regulator, new fuel hose, new fuel return hose, new fuel filter. Nada. No codes, she wants to start with a little starter fluid so she just isn't getting fuel. Ideas? Anyone!
davbib is offline
post #9 of 19 Old 11-01-2014, 7:38 PM
Reputation Power: 17
Make sure you are not crimping a fuel hose or squashing one when you refit the fuel tank and that you have connected the lines correctly, remove one line at a time to check that there is no metal/rust swarfes from the tank blocking a line.
Kevo954 is offline
post #10 of 19 Old 11-01-2014, 8:19 PM
Quoted: 120 Post(s)
I'm stumped. I know you've probably checked and rechecked your hoses and routing. Pump primes, right? You mentioned you could hear it.
There's a test in the manual that has you check for fuel volume by disconnecting the fuel supply hose (at the injectors, irrc), and running the fuel pump for a certain amount of time. Then you measure how much fuel is in the pale and see if it's enough. A fuel pressure test may be in order too.
But it still sounds like blockage of some sort. Weird... Injectors? Kickstand switch?
jondog9 is offline
post #11 of 19 Old 11-01-2014, 9:02 PM Thread Starter
Yeah, kind of a mystery. I would think if it was getting not enough fuel it would kick a bit, but it's just cranking (unless I give it a shot of starter fluid) so I think tomorrow I'll disconnect the fuel line at the throttle body and see if it's got any fuel there at all.
Any chance my power commander went bad and it's causing this? It's powering up and everything but now I gotta start looking at least likely.
I'll double check the hoses again, but since I just replaced then I'm pretty sure that's not it.
davbib is offline
post #12 of 19 Old 11-02-2014, 3:54 AM
hmk
Could be unrelated, but how does you spark plugs look? Always nice to check their colour for diagnosing
Ride safe!
hmk is offline
post #13 of 19 Old 11-02-2014, 10:39 AM
Quoted: 120 Post(s)
I would definitely unplug the power commander to eliminate it from the equation. That's a basic part of diagnosing most problems a bike may have. process of elimination
jondog9 is offline
post #14 of 19 Old 11-02-2014, 5:55 PM Thread Starter
Thanks Jon. I'll try that next weekend and let you know what I discover. Ran out of time today.
davbib is offline
post #15 of 19 Old 11-02-2014, 6:08 PM
Quoted: 47 Post(s)
Reputation Power: 47
anytime someone has a FI related problem my first piece of advice is to unhook the pc. ive seen it with my own eyes more than once where it fixes the problem.
954Kevin is offline
09 Cbr1000 tried to start by itself. Now won't start. anti_everything General Discussion 9 05-20-2012 10:33 AM
954 no start after shim check mondo Honda FireBlade 3 08-07-2010 6:15 AM
1999 Fireblade hard start, now wont start.... MFB_87 Honda FireBlade 15 03-18-2010 11:58 PM
'00 F4 - Won't Start, where do i start? cranks but doesnt fire. dunkd Honda CBR 600 7 07-30-2007 5:32 PM
929 will not start after valve check Seeker Honda FireBlade 18 08-20-2003 10:20 AM
