Is this standard or aftermarket? - Honda Motorcycles - FireBlades.org
post #1 of 8 Old 10-25-2014, 12:06 AM Thread Starter
Quoted: 39 Post(s)
Reputation Power: 23
Just wondering what exhaust this is, the bike came with a Hindle slip on when i bought it back in 1873, but never really gave it any thought till recently.
Its got the spring thingos on every join.
cbr exhaust 002.jpg‎   cbr exhaust 001.jpg‎   cbr exhaust 003.jpg‎
Squid is offline
post #2 of 8 Old 10-25-2014, 1:43 AM
Reputation Power: 27
Re: Is this standard or aftermarket?
Wrote before reading, but is there any numbers stamped anywhere on it?
Mikeo is offline
post #3 of 8 Old 10-25-2014, 3:48 AM Thread Starter
Quoted: 39 Post(s)
Not that i have noticed. It appears to be thin-wall steel that was chrome plated but now just rusty. The muffler said Hindle Stealth on it.
The plastics are back on now, but might get it out during the week so i can clean it up and give it a coat of flame-proof paint. Will look out for any numbers as i go.
Squid is offline
post #4 of 8 Old 10-25-2014, 9:40 AM
Quoted: 734 Post(s)
Reputation Power: 102
Definitely aftermarket. If it had a Hindle can on it I would just assume it's a full Hindle system. No standard system on the 900's ever had spring retained joints.
IanDoohan is offline
post #5 of 8 Old 10-25-2014, 11:31 AM
Reputation Power: 291
Jaysus squid arnt you a bit old for a sports bike?
Irish's Blog Page
Hate this Skin
Assalam-o-Alaikum
setanta is offline
post #6 of 8 Old 10-25-2014, 5:18 PM Thread Starter
Quoted: 39 Post(s)
Makes me wonder if its got a jetting kit too. Any way of telling by looking at the carbies externally?
Lol, I dont feel a day over 100
Squid is offline
post #7 of 8 Old 10-25-2014, 8:06 PM
Quoted: 734 Post(s)
Not really. On the older ones like ours the factory would seal the fuel/air screws with an aluminum plug (before the advent of the D shape screw head). Sometimes if the aluminum plugs are gone it's a way to tell its been jetted. My guess would be yes, as it would give you signs with a full exhaust that it may be running too lean. Pop the carbs off and then the choke rail, or if you're daring leave the carbs on and take the choke rail off. Pull the vacuum top off a carb and remove the slide. Using a screw from the carb top, thread it into the center of the slide. Give it a good tug and it will come out, allowing you to push the needle out. Be careful, there's probably a washer in there under the needle. If you have multiple grooves in the needle and a c-clip they are adjustable, and more than likely a jet kit is installed. It's uncommon to only have adjustable needles and no added jets.
post #8 of 8 Old 10-25-2014, 9:10 PM Thread Starter
Quoted: 39 Post(s)
^ ok thanks. Well it hasn't been running lean so probably does have something going on.
Im taking it in for a tune and general check over hopefully this week, will be interesting to see what comes up.
In other news, just installed a K&N air filter after reading about how useless they are. I was just hoping for a bit more induction noise. No appreciable difference in noise or go.
Thing i found funny is they have re-invented the divider between the front and back of the air-box for some reason. Instead of fitting into the groove like oem, it comes down further and overlaps it (and requires slight trimming to fit), thus changing the shape of the insides of the box slightly, as well as loosing what ever seal there was between the front and back of the box. I dunno about it. Might have to get an OEM Honda one back in there.
Squid is offline
Aftermarket cooling fan/aftermarket wiring Krystalized_jdm Honda FireBlade 1 08-09-2014 1:31 AM
97 Fireblade RRV Standard Can IDLE Wanted 2 09-16-2013 9:50 AM
929 Aftermarket Plastics For Aftermarket Pipe! FTP_929 Swap Section 9 05-27-2010 3:40 AM
PC3 on standard 954 ag1s Honda FireBlade 7 12-27-2008 3:21 PM
954 Standard Heavy-Dee Honda FireBlade 1 03-01-2006 7:45 PM
