cbr wont start - Honda Motorcycles - FireBlades.org
post #1 of 8 Old 10-26-2014, 2:06 PM Thread Starter
cbr wont start
hi all im new to the site and just bought my first cbr, currently im trying to get it sorted and running again, ive cleaned the plugs and i get a spark, there seems to be fuel there but the plugs are black and have fuel around them, it used to missfire but now i cant get it started, and to top it off i went to adjust the mix screws and the 2 carbs in the middle have both got broken mix screws, all it will do is turn over and backfire, any help or advice would be highly appreciated
grant1985 is offline
post #2 of 8 Old 10-26-2014, 7:12 PM
Quoted: 734 Post(s)
Reputation Power: 102
Re: cbr wont start
What year, and what other history can you give us about it? Have you tried starter fluid to see if it runs? Replace all the mixture screws if that's the case.
RRV, got it from your other post..
IanDoohan is offline
post #3 of 8 Old 10-27-2014, 12:38 AM Thread Starter
Re: cbr wont start
I tried starter fluid but it fired and didnt start attempted again and it failed im thinking thr plugs are fooked but how can i change the mixture screws if the 2 middle carbs have the heads of screws snapped off?
post #4 of 8 Old 10-27-2014, 1:14 AM
Quoted: 734 Post(s)
Re: cbr wont start
Seems like a fueling issue. As far as the screw heads being snapped off how can you tell? Have you had the carbs out? The fuel mixture screws for that model I believe are a solid core screw, meaning there is no real "head" to snap off. It would had to have broken at the taper part where the needle is. I say that because that would be he weakest part of the screw. The heads should not have any slots in them and should be D shaped requiring a special tool. However, in reality we all know that stranger things have happened and being a soft brass screw it's very possible that it snapped at the threads. They can be drilled out, very carefully. Any chance of posting a detailed pic of one or both?
post #5 of 8 Old 10-27-2014, 7:56 AM Thread Starter
Re: cbr wont start
same crews as this pic so now i dont have the cross engraved anymore its just flat and nothing to grip on. both end carbs are set at 3 turns i clearly cant tell yet what the 2 middle ones are, if they are set at 3 turns then where would i look next to adjust to stop it running rich and hopefully it will help it to start.
post #6 of 8 Old 10-27-2014, 7:57 AM Thread Starter
Re: cbr wont start
Redirect Notice
post #7 of 8 Old 10-27-2014, 7:58 AM Thread Starter
Re: cbr wont start
the last link shows in the 1st image of what i mean. i couldnt upload a piccy for some reason
post #8 of 8 Old 10-29-2014, 3:50 AM
hmk
Re: cbr wont start
One of those broke for me too.. i just cut a line in it for a flat head using a dremel. Using 2.5 turns out btw.
Had same problem as you, the screws was at 3 3/4 turns. Also had to air out excessive gas by having the carbs out over night.
Ride safe!
hmk is offline
95 cbr 600 f3 wont start help please! ablopez Honda CBR 600 21 08-13-2013 1:42 AM
HELP! 02 F4i Wont Start RideTheSquirrel Honda CBR 600 14 01-25-2011 10:50 PM
1999 Fireblade hard start, now wont start.... MFB_87 Honda FireBlade 15 03-19-2010 12:58 AM
954 wont start bryanclapper69 Honda FireBlade 2 03-18-2007 7:11 PM
CBR 929 WONT START kalaiz69 Honda FireBlade 0 02-18-2005 10:13 PM
