954 died and lost all power - Honda Motorcycles - FireBlades.org
post #1 of 10 Old 10-27-2014, 3:25 PM Thread Starter
Reputation Power: 8
I have an 02 954 with 27k on it. Battery tested GOOD so I know its OK there. Here is what happened - started bike letting it warm up and all of a sudden it shut off. Still had juice so started it and went to get gas at local station - it cut out and shut off. Lost all power to gauges, etc. Charged battery and it will start again but seems to be draining the battery.
Would anyone have any input as to whether or not the issue is a bad regulator?
Bike is all original and I am original owner. Any input is appreciated before I would order a regulator.
Thanks!
2000 CBR929RR
2002 CBR954RR
2003 CBR954RR
2003 CR250
2006 VTX 1300C/N
2007 VTX 1800F
2012 CRF50 (stunt)
2013 DRZ400sm
1bad954rr is offline
post #2 of 10 Old 10-27-2014, 10:28 PM
Re: 954 died and lost all power
Grab a multimeter and check what voltage it is charging at.
Kevo954 is offline
post #3 of 10 Old 10-28-2014, 5:39 AM Thread Starter
Reputation Power: 8
I had the battery tested and it showed 12.6 volts. Is that what you mean?
I am not all that good when it comes to electrical.
post #4 of 10 Old 10-28-2014, 2:48 PM
Take it to a mechanic, not a forum.
blunt is offline
post #5 of 10 Old 10-28-2014, 2:54 PM
Quoted: 120 Post(s)
Reputation Power: 199
12.6 volts at rest is pretty weak. I can see your bike demanding more power than that to stay running if your stator or reg/rec aren't charging enough.
Test your reg/rec with a multi meter, and your stator too.
The only catch is the bike should be warmed up to operating temp to get accurate readings.
jondog9 is offline
post #6 of 10 Old 10-28-2014, 2:56 PM
Quoted: 120 Post(s)
I disagree. There's plenty of good info around here that he can start with to see if he can solve the problem without relying on someone else who's going to charge a pretty penny for electrical issues.
Edit: I'm not a mechanic, I'm not experienced with motorcycle electrical. But I've researched and asked enough questions to discover how to test my stuff and resolve problems. It's not all that difficult, but a good learning experience.
Here's my last go at testing my Reg/rec and stator. If you see problems with the content - please feel free to comment.
https://www.fireblades.org/forums/hon...tor-tests.html
jondog9 is offline
post #7 of 10 Old 10-28-2014, 7:09 PM
Grab a multimeter and test the rr and stator. My money is on one of those being bad. Your manual should have instructions on how to do that.
TylerD954 is offline
post #8 of 10 Old 10-28-2014, 9:38 PM Thread Starter
Reputation Power: 8
jondog9 and TylerD954 Thank you both for the replies and information. I will picking up a multimeter and testing. Ill check in the service manual.
Thanks again guys!
2000 CBR929RR
2002 CBR954RR
2003 CBR954RR
2003 CR250
2006 VTX 1300C/N
2007 VTX 1800F
2012 CRF50 (stunt)
2013 DRZ400sm
post #9 of 10 Old 10-28-2014, 10:28 PM
Quoted: 49 Post(s)
Reputation Power: 48
here are the simple tests for charging system components.
http://www.electrexworld.co.uk/acata...P-PMG-&-RR.pdf
954Kevin is offline
post #10 of 10 Old 10-29-2014, 1:01 AM
Originally Posted by jondog9 View Post
I disagree.
An electrical test at ANY SHOP is going to be FAR more practical and affordable to anyone, including you, in testing and diagnosing electrical/charging issues. I work in a shop that does that most of the time, for free.
blunt is offline
Lost Power w my 929 cbr 2001 GWIZ General Discussion 8 07-16-2013 3:10 PM
929 Power Commander Died 954 Fitted. ganzeegeezer Honda FireBlade 6 01-19-2013 10:26 PM
HELP. 03 F4i lost power after CCT install Daetok General Discussion 12 09-08-2012 5:16 AM
96 f3 lost power while riding ride2liv Honda CBR 600 3 03-12-2008 11:56 PM
Lost power at 5000 ft paularthur Honda FireBlade 8 07-23-2004 7:39 AM
