Easiest engine removal method? - Honda Motorcycles - FireBlades.org
post #1 of 11 Old 10-30-2014, 7:13 PM Thread Starter
Reputation Power: 6
Is there a preferred/suggested way to remove the engine? Or is what's in the manual pretty much it? I need to remove my heads and god knows what else I'll find while I'm in there.
I saw this one on youtube. It seems like this would rid me of the need to purchase an engine stand and an engine hoist.
KingDoom is offline
post #2 of 11 Old 10-31-2014, 1:17 AM
Re: Easiest engine removal method?
From what sort of vehicle?
Fireblades you just put a crate or something under the engine and remove the bike from the engine.
I have never used an engine stand or a hoist for any motorcycle engine, and rarely for car engines. Even my old CB1100F engine only weighed 82kg, Blade engines are barely over 60kg, less if you strip parts off first, like the starter motor, alternator and clutch if you think you're going to struggle with the weight.
I just helped a mate pull out a GSX1100 engine last Sunday, and helped lift the new one out of his car - with a broken right shoulder.
By "heads" do you mean a V-engine of some kind?
post #3 of 11 Old 10-31-2014, 9:13 AM
Reputation Power: 26
This is what I did. Was fairly straightforward if you follow my article and the manual. It went back together maybe even a bit easier than taking her apart..
Have fun!
https://www.fireblades.org/forums/art...misc-tips.html
Honda CBR 954RR (Leslie)
Suzuki SV650-K2
Camper is offline
post #4 of 11 Old 10-31-2014, 10:32 PM
Quoted: 3 Post(s)
Reputation Power: 25
my 06-07, was a lot harder then that!!!
tweezy666 is offline
post #5 of 11 Old 11-01-2014, 1:05 AM
Quoted: 39 Post(s)
Squid is offline
post #6 of 11 Old 11-01-2014, 2:23 AM
Quoted: 748 Post(s)
Reputation Power: 102
This is how I got my 93 motor out by myself, no vid, just pics. Hanging the frame vs. using the rear stand is a good option as well. I used the tie downs you see to lower the front of the engine. It took some finagling to get the rear portion undone, but once it was loose I was able to then lift the frame up via tie downs and slide the motor out to the left as shown in the last pic. Good luck however you get it out.
IanDoohan is online now
post #7 of 11 Old 11-01-2014, 3:36 AM
Originally Posted by Squid View Post
Very straight forward, highly recommended.
blunt is offline
post #8 of 11 Old 11-01-2014, 4:37 PM
Quoted: 120 Post(s)
Reputation Power: 199
Ok, but I'd be afraid of scratching the oil pan.
jondog9 is offline
post #9 of 11 Old 11-01-2014, 8:47 PM
Quoted: 49 Post(s)
Reputation Power: 48
hold on ian? was that actually the install just in reverse... lol
954Kevin is offline
post #10 of 11 Old 11-01-2014, 9:16 PM
Quoted: 748 Post(s)
Pretty much, except for the cam cover color
post #11 of 11 Old 11-03-2014, 5:16 PM Thread Starter
Reputation Power: 6
I just finished moving in to my new place over the weekend. I'll probably get cracking on this come Saturday.
I'll probably do something similar to you Ian.
KingDoom is offline
CBR 929 RRY 2000 Engine removal elliottanner Honda FireBlade 2 05-15-2012 4:04 AM
929 Engine Removal Opinions Cbrrrrrr929 Honda FireBlade 7 01-20-2012 11:31 PM
Engine removal throttlebody a must? Midwestrider Honda FireBlade 2 07-22-2011 2:55 PM
Bad cylinder in 954, engine removal advice. jimedreg Honda FireBlade 15 11-23-2010 10:24 AM
Sticker removal, Your method and results. maxredline Honda FireBlade 24 09-07-2006 10:38 PM
