Lots of wiring help please - Honda Motorcycles - FireBlades.org
post #1 of 10 Old 12-15-2014, 11:52 AM Thread Starter
Quoted: 43 Post(s)
Reputation Power: 7
I have reached the point where I need to work on the bike loom. I've had a look through the wiring diagram but still have some questions which I hope you can help with. Even if you can just help with 1 I'd appreciate it ...
1. Are these two wires that are linked here for the horn normally?
2. What do these two spade clips in plastic shields go to?
3. What is the separate wire coming out of this grip thing?
4. Is this light on all the time when the engine is on? If so I think I'll link it to my sidelights and number plate light - anyone know how much current I can pull through it before making things unhappy? I'm not going to do too much but a relay would be an added pain I would like to avoid
5. Is this the main igt switch?
6. Is 4x10A then a gap before the 20A normal? Looks right to the wiring diagram I have
7. Just an engine ground?
8. No idea what these two dangling are?
9. Are these 4 pin connectors rear lights/indicators?
10. Don't know what this one is:
jseaman is offline
post #2 of 10 Old 12-15-2014, 11:53 AM Thread Starter
Quoted: 43 Post(s)
Reputation Power: 7
Re: Lots of wiring help please
11. Is this a standard stop/tail and can I run two off it?
12. Again, not a clue on these 3:
13. I'm assuming the black wire goes here as a crank sensor?
14. And the blue wire from 13 goes to a temp sender here
15. TPS?
16. I think these are coil pack wires
17. Speedo sender?
18. Is this for a stand? If so do I make/break the wires to bypass?
19. Does this white 3 pin multiplug connect to the stator?
jseaman is offline
post #3 of 10 Old 12-15-2014, 12:07 PM
Quoted: 734 Post(s)
Reputation Power: 102
Ok buddy here we go, as best I can:
1-no. Clutch switch
2- horn wires
3-brake light switch
4-yes/unknown
5-yes to ignition switch
6- maybe
7- yes to frame
8-turn signals
9- no / yes - relays for hi-lo and turn signals
10- fan switch connector
11- yes and probably
12- the other side turn signals
13- ignition rotor (advancer)
14- yes
15-yes
16- yes
17- yes
18-yes and maybe trial and error
19- yes
And breathe.................
IanDoohan is offline
post #4 of 10 Old 12-15-2014, 12:22 PM Thread Starter
Quoted: 43 Post(s)
Reputation Power: 7
You are a legend!
1. Great so the clutch switch is shorted so you don't have to depress the clutch to start the car I assume, I'll make that permanent
2. Ticked off, thanks
3. OK I can't use that but have another so that can go, am I OK to leave it open circuit?
4. I'll try it and see what breaks then!
5. Great, I don't suppose you know what wires do what
6. I'l run with it for now and see what happens then
7. Great, I'll ground that
8. Oh, front or rear do you know?
9. Cool - do you happen to know the pin outs as I don't have the other end of this connector
10. Brilliant, the fan's in the house which explains why I couldn't find a place for this!
11. Cool
12. 3 wires? Is it 1 ground and 2 live for turn signals?
13. What the heck is an ignition rotor?!
14-19 great
Thank you so much for that, you've given me a huge step forward - sincere thanks!!
jseaman is offline
post #5 of 10 Old 12-15-2014, 12:42 PM
Quoted: 734 Post(s)
Originally Posted by jseaman View Post
You are a legend!
11. Cool
14-19 great
3- yeah I'm sure you'll figure out if you need to connect it for a brake light. Not a huge deal
8- off the top of my head no, but it's left and right. The ones you displayed in the pics were for the front I believe. The 3 wires allow for running lights as well as turn signals.
9-I have no idea as to what goes where for the relays, but I may have pics I could dig up.
13- it's the "pulse generator" for the ignition spark.
My pleasure.
post #6 of 10 Old 12-15-2014, 12:51 PM Thread Starter
Quoted: 43 Post(s)
Reputation Power: 7
OK I won't take any more of your time just yet but you've given me enough to make some serious headway for now. Thank you so much for such a fast and comprehensive response - I'm sure I'll be back with more queries but for now huge thanks again
jseaman is offline
post #7 of 10 Old 12-15-2014, 12:54 PM
Quoted: 734 Post(s)
Cheers JS.
post #8 of 10 Old 12-18-2014, 2:02 PM Thread Starter
Quoted: 43 Post(s)
Reputation Power: 7
Just to conclude this, you were bang on with the advice.
1. I have bypassed the clutch switch properly now, it is just a case of making continuity between the two wires to the grip
2. The horn switch doesn't work but I'll figure that out later!
3. brake light switch can be left open circuit
4. I'm going to run a relay as I'm pulling front and rear side lights plus number plate light off this
5. The main igt switch is getting sorted with a heavy duty switch
6. I found a few other pics so it looks like the gap is normal
7. Engine ground has been mounted on the starter
8. They are indeed indicator wires
9. Separate thread about these relays about to go up
10. Fan switch is redundant as I'll be doing this differently
11. OK to run two tail lights
12. Yup indicators!
And the rest is covered earlier in the thread, just in case any of that helps anyone else
jseaman is offline
post #9 of 10 Old 12-20-2014, 4:33 PM
Reputation Power: 8
Wow! I feel like I just witnessed a miracle! A legend for sure. I'm approaching re-wiring my 954. The first owner did some hack job on all the aftermarket lights plus it's not charging. I was hoping to get a makeover for the body, but I think this electo job is gonna wear me out for awhile.
Beyond fear is freedom.
SA954RRWA542 is offline
post #10 of 10 Old 12-20-2014, 4:56 PM Thread Starter
Quoted: 43 Post(s)
Reputation Power: 7
I must say it's not a difficult set of wiring (especially is leaving it stock) but you just need a few nudges from people in the know and Ian is certainly one of them!
jseaman is offline
Parts for sale, lots. Engine parts...mostly. Some wiring stuff. But mostly engine squeeze For Sale 9 08-12-2010 6:19 PM
F4I PARTS!!! LOTS OF THEM! undercvr_skank For Sale 12 03-09-2009 4:01 AM
WTB; Lots of 954 Parts speedaddict Wanted 6 10-08-2005 1:47 AM
02 954 with lots of goodies! slowpoke For Sale 4 07-14-2005 4:18 PM
Lots Of Snow ConqSoft Off-Topic 2 01-22-2004 4:25 PM
