My first significant issue - Honda Motorcycles - FireBlades.org
post #1 of 5 Old 12-21-2014, 5:37 PM Thread Starter
Quoted: 49 Post(s)
Reputation Power: 7
I decided to pop my rocker cover on tonight and, after laying it down, popped the bolts in and nipped them up. I reached down on the exhaust side and could feel a gap between the gasket and cover, gave it a little rock and there was indeed a lot of free movement in the cover itself. I thought I'd nip up the bolts to address this .. it sheared. I know the gasket wasn't trapped so haven't figured out why there was movement yet but I now have a broken stud to extract and a missing rocker cover bolt - anyone got any spares?!
jseaman is online now
post #2 of 5 Old 12-23-2014, 4:44 AM Thread Starter
Quoted: 49 Post(s)
Reputation Power: 7
Re: My first significant issue
I extracted the bolt with nothing more than a small screwdriver, wasn't tight at all. That's out and a set were found on ebay so hopefully shouldn't hold things up
post #3 of 5 Old 12-23-2014, 4:42 PM
Quoted: 120 Post(s)
Reputation Power: 199
What caused the valve cover to not seat? Sounds like you thought you had the bolts all snugged up, but cover was still loose?
jondog9 is offline
post #4 of 5 Old 12-23-2014, 5:52 PM Thread Starter
Quoted: 49 Post(s)
Reputation Power: 7
No idea, took it all off (gasket was here it should be) and refitted it 'dry' and it seated fine. After that I put sealant on the half moons and it dropped in as expected. I just put it down to one of those things sent to ruin your day
That said, a quick search shows a lot of people having snapped rocker cover bolts, it may be worth changing these if pulling the cover off in the future
post #5 of 5 Old 01-12-2015, 2:07 PM Thread Starter
Quoted: 49 Post(s)
Reputation Power: 7
For completeness, the rubber washers were missing from the bolts so they were seating too far in the head which was stressing them and meaning they didn't clamp the cover. Fitting some washers fixed the problem!
1 issue fixed, major issue happened Dudirtt Honda FireBlade 6 04-06-2012 12:35 PM
954 Issue(s) Help!? jawz0414 Honda FireBlade 5 06-21-2008 11:14 PM
dg8 issue cbr_df Honda FireBlade 6 02-02-2008 3:44 AM
Does your significant other let you ride or is it a fight? nomad General Discussion 112 06-18-2005 11:46 AM
