Just bought another 929 thats been sitting for years - Honda Motorcycles - FireBlades.org
post #1 of 13 Old 12-24-2014, 3:32 PM Thread Starter
Reputation Power: 7
I just purchased a 2001 Erion Racing edition. It even has the Erion can from the dealer. Paid $1000 for it. Clean title Oh and the casing hasn't been welded from being dropped.
Here the problem.
The bike has sat for a couple of years. It got put up with a fueling issue. Fuel pump not priming. It did get bumped over to show me the motor is not locked up but it was just a bump since its been sitting. He didn't want to keep turning it. I don't have the bike for another two weeks. Couple of questions...
Fuel pump, I'm gonna check the ignition(I have a known working one), hard wire the pump itself to test it, and check the TIP sensor and fuel cut relay.
As far as it sitting for a while, oil change, coolant flush, should i drop a few drops of oil into the cyl to lube it up? and what else? I didn't see any rust inside of the tank so it has a good seal. I am going to take the old gas out and put fresh in it.
I parted my old running 929 out but I still have complete motor w/ TBs and injectors. Should I swap them out since the gas in the injectors could be gelled?
It also has a track front fairing on it. I need to source a stock front and headlight.
2001 Honda CBR929RR Erion Racing Edition - Current
2001 Honda CBR600RR F4i Stunt bike - Current
2000 Honda CBR929RR Street Fighter - Parted out 8-2014
2006 Kawasaki Ninja 500R - Wadded Up 6-30-12
th3cavalry is offline
post #2 of 13 Old 12-24-2014, 7:03 PM
Quoted: 2 Post(s)
Reputation Power: 10
Re: Just bought another 929 thats been sitting for years
You should spray some WD-40 into the cylinders it penetrates (Giggedy) better, oil might foul up the plugs. My 929 sat for 2 1/2 years and the gas was bad but not jelly, even started it up with bad gas no harm just smelled terrible. Throw in some Lucas FI cleaner with fresh gas and you should be good.
2016 KTM 1290 Super Duke R
1993 Kawasaki KLR 650
2001 929RR (Sold but bike is still in the family)
Pablo.gyds03 is offline
post #3 of 13 Old 12-24-2014, 9:45 PM Thread Starter
Reputation Power: 7
thanks man! I'll def do that. I want to freshen it up before i fix it and get it running
post #4 of 13 Old 12-24-2014, 11:26 PM
Quoted: 120 Post(s)
Reputation Power: 198
Be ready for the fpr to give out. The diaphragm rots after a short period of sitting with todays gas.
Put fresh plugs in.
Change all fluids including fork oil and set riders sag.
Congrats on a great bike!!
jondog9 is offline
post #5 of 13 Old 12-25-2014, 7:45 AM
Quoted: 13 Post(s)
Always loved the Erion 929, has always been one of my favorite schemes. Post up some pics when you get the chance.
1996 Honda CBR 900RR Fireblade
2001 Honda RC51 SP1
2003 Aprilia RSV Mille R
1999 Aprilia RS50
2012 Triumph Daytona 675R
RC51 Build- http://tinyurl.com/SP1-Project
CBR 900RR Build- http://tinyurl.com/oe7dfmf
gts455 is offline
post #6 of 13 Old 12-25-2014, 1:10 PM
Quoted: 120 Post(s)
Originally Posted by th3cavalry View Post
The bike has sat for a couple of years. It got put up with a fueling issue. Fuel pump not priming. ...
I'm pretty sure your 929 has a relay for the tip sensor. I think they call it the *engine stop relay*. (On my bike they call it the bank angle sensor and bank angle relay.) If it's bad, it'll give you a no-fuel-prime too.
jondog9 is offline
post #7 of 13 Old 12-25-2014, 10:31 PM
WD-40 is the last thing I'd spray in there before a start up. It is too thin to protect and will wash off any of the motor oil you had on the cylinders. Foul the plugs, it's worth it. Change the oil too. The important thing is once you start it, keep it running to full operating temperature, take it for a ride. I stored my ZX6R for 3 years, put in a little bit of oil in each cylinder overnight, and it fired right up and ran fine after 2-3 minutes for the smoke to clear. It needed a set of plugs anyway. WD-40 is not a cylinder lubricant. It penetrates rust, which probably doesn't exist in the cylinder anyway. You need a little oil, to protect the rings and cylinder wall on start up.
blunt is offline
post #8 of 13 Old 12-31-2014, 5:21 PM
Quoted: 29 Post(s)
To blunt's comments!
jdoni is offline
post #9 of 13 Old 12-31-2014, 8:49 PM
ya i bought a nice 2001 929 the casing was welded,brake side,being the bike was traded in bye a car dealer,he had no clue,for 1500 is a good bike,HAPPY NEW YEAR ALL
joejoe1960 is offline
post #10 of 13 Old 01-01-2015, 7:40 PM
Reputation Power: 8
Pretty please
cbrherms is offline
post #11 of 13 Old 01-01-2015, 7:49 PM
heres 1 doing new tires,chain,rotor,pads
rr900 001.JPG‎
post #12 of 13 Old 01-02-2015, 10:33 PM Thread Starter
Reputation Power: 7
I'll get some pictures soon. It was a track bike and has track plastics. The tank is still the red, white, black scheme so I plan on trying to get some matching plastics soon. For the time being im just going to plastidip everything black and call her black betty.
post #13 of 13 Old 01-02-2015, 10:56 PM
SEEMS IM NOT WELLCOME NO COMMENTS TAKE CARE CREW
954rr sitting for 9 years now smoking blue u0636767 Honda FireBlade 5 10-03-2012 5:50 PM
bought a bike from a forum member here a few years ago, just pulled off the airbox 9uno9 General Discussion 2 03-15-2012 11:17 PM
600 F4i sitting Two Years TheF4Iguy Honda CBR 600 3 07-10-2007 5:23 PM
Anyone else sitting at home? ND4SPD Off-Topic 31 07-05-2005 5:08 PM
What needs to be done to my sitting bike? Nick the Quick General Discussion 6 03-25-2004 1:16 AM
