GTS455 CBR900RR SC33 Build - Honda Motorcycles - FireBlades.org
 19Likes
Old 12-27-2014, 6:38 AM Thread Starter
Quoted: 13 Post(s)
Reputation Power: 10
I promised a thread of my resurrected SC33, so here it goes.
January 2013 i moved to germany, and decided with work and a growing family i would not have the time or the work space to deal with a motorcycle. I left all my bikes back in storage in the States. That lasted a whole 4 months before i was cruising the economy for a cheap buy. After looking at several, VFR400's i came across a 1996 CBR 900RR. I had never owned a CBR, but have always been like Honda Sport bikes....especially being a RC51 enthusiast. It was within my budget (was not willing to spend more then 2000 Euro), and i have to say what grabbed my attention off the bat was the paint scheme. Early August i went and test rode the bike and brought it home the same day. It was dirty, not abused but not cleaned or well taken care of. I knew it would be a project but figured most of it just needed refreshing. On the outside and in pictures it didn't look bad at all, but up close years of neglect were showing, and it had been tipped over at least twice....but not rashed up from a drop at speed. Anyway, i took the risk knowing it would be a little work and got it for just under 2000 Euro. What i would later find was a lot of corrosion
The CBR was originally sold on the Italian market then sold by the original owner to a man in his 40's who was using it as a tourer, whom i bought it from.
Pics from the day i brought it home.
IMG_0928 by gts455, on Flickr
IMG_0926 by gts455, on Flickr
IMG_0927 by gts455, on Flickr
IMG_0931 by gts455, on Flickr
1996 Honda CBR 900RR Fireblade
2001 Honda RC51 SP1
2003 Aprilia RSV Mille R
1999 Aprilia RS50
2012 Triumph Daytona 675R
RC51 Build- http://tinyurl.com/SP1-Project
CBR 900RR Build- http://tinyurl.com/oe7dfmf
gts455 is offline
Old 12-27-2014, 6:54 AM Thread Starter
Quoted: 13 Post(s)
Re: GTS455 CBR900RR SC33 Build
I was determined to keep this bike on a budget. So i was extremely tedious finding parts at a good price. That being said the bike sat, while i got parts together. Among the parts was a used but spotless and clear wind screen (Mine was destroyed by the sun, as well as the Brake fluid reservoir and both were showing cracks), Leo Vince slip on , OEM Fork seals,SP1 Calipers , Carbonne Lorraine CL5 Pads, HEL Braided lines, and tires.
In October 2013, i began to tear the bike down to get a better idea what i was dealing with. What i found was a bit worse then i expected. Rusting and pitted headers, road grime completely covered the engine and frame, and a corroding radiator....with rust inside. I also pulled the rim tape off which took most of the wheel paint with it.
IMG_2222 by gts455, on Flickr
IMG_2224 by gts455, on Flickr
IMG_2226 by gts455, on Flickr
IMG_2235 by gts455, on Flickr
IMG_2227 by gts455, on Flickr
IMG_2231 by gts455, on Flickr
2001 Honda RC51 SP1
1999 Aprilia RS50
gts455 is offline
Old 12-27-2014, 6:59 AM Thread Starter
Quoted: 13 Post(s)
The tear down and cleaning began and took place all through the winter.
IMG_2416 by gts455, on Flickr
IMG_2417 by gts455, on Flickr
IMG_2418 by gts455, on Flickr
IMG_2415 by gts455, on Flickr
IMG_2412 by gts455, on Flickr
2001 Honda RC51 SP1
1999 Aprilia RS50
gts455 is offline
Old 12-27-2014, 7:08 AM Thread Starter
Quoted: 13 Post(s)
As i dumped fluids....it got worse. Brown Brake fluid. Dark blue coolant with rusty sludge coating all the hoses. At this point i decided to replace the hoses. Perfect excuse for some Samco hoses.
I also pulled the forks and wheels. Forks were pitting on bottom and i figured the needed a good cleaning and rebuild which they did. When i pulled them apart i found Gray sludge in the valves. I would not have been surprised if this was the original fluid. Measured up the springs and everything is still well within spec.
Once the forks were pulled i replaced the bearings and races in the steering stem and regreased everything.
IMG_2420 by gts455, on Flickr
IMG_2421 by gts455, on Flickr
IMG_2422 by gts455, on Flickr
IMG_2423 by gts455, on Flickr
IMG_2425 by gts455, on Flickr
Gunk likes this.
2001 Honda RC51 SP1
1999 Aprilia RS50
gts455 is offline
Old 12-27-2014, 7:11 AM Thread Starter
Quoted: 13 Post(s)
March, i stripped the Radiator and flushed it.....several times to rid it of any residue. Pulled the water pump which showed the extent of the damage. Found a used one in good condition and also replaced the housing and thermostat.
IMG_2452 by gts455, on Flickr
IMG_2453 by gts455, on Flickr
IMG_2630 by gts455, on Flickr
IMG_2635 by gts455, on Flickr
2001 Honda RC51 SP1
1999 Aprilia RS50
gts455 is offline
Old 12-27-2014, 7:15 AM Thread Starter
Quoted: 13 Post(s)
At this point i also pulled the valve cover and checked the clearances. I had several on the edge so i got everything dead center, buttoned it back up, gave it nw plugs, and got it some well deserved oil.
IMG_2626 by gts455, on Flickr
2001 Honda RC51 SP1
1999 Aprilia RS50
gts455 is offline
Old 12-27-2014, 7:21 AM Thread Starter
Quoted: 13 Post(s)
Once the weather warmed up, i stripped all the rust off the exhaust and gave it a few coats of paint.
IMG_2629 by gts455, on Flickr
Then i finished getting the radiator painted and back together.
IMG_2623 by gts455, on Flickr
IMG_2624 by gts455, on Flickr
I also got the forks flushed, seals replaced, and bottoms refurbished with paint and clear coat.....all done in the back yard.
IMG_2632 by gts455, on Flickr
IMG_2633 by gts455, on Flickr
IMG_2634 by gts455, on Flickr
2001 Honda RC51 SP1
1999 Aprilia RS50
gts455 is offline
Old 12-27-2014, 8:31 AM Thread Starter
Quoted: 13 Post(s)
At this point i replaced a lot of worn rubber grommits and gaskets. The exhaust got all new gaskets, stator cover, water pump, clutch cover, new oil filter. It took me awhile but i also stripped both wheels and repainted them.
Both the stator cover and clutch cover came off and for sanded down a bit to rid the pitting from the tip overs and both were repainted.
IMG_2648 by gts455, on Flickr
IMG_2650 by gts455, on Flickr
IMG_2651 by gts455, on Flickr
2001 Honda RC51 SP1
1999 Aprilia RS50
gts455 is offline
Old 12-27-2014, 8:34 AM Thread Starter
Quoted: 13 Post(s)
I also cleaned up the subframe area which was also covered in grime, and began polishing up the frame, swingarm, and subframe.
IMG_2642 by gts455, on Flickr
IMG_2640 by gts455, on Flickr
2001 Honda RC51 SP1
1999 Aprilia RS50
gts455 is offline
Old 12-27-2014, 8:38 AM Thread Starter
Quoted: 13 Post(s)
May 2014, the reassembly really began. With the cooling system completely replaced, brake system flushed and hoses replaced with HEL braided lines and new reservoirs it all started to come back together.
IMG_0082 by gts455, on Flickr
IMG_0083 by gts455, on Flickr
IMG_0081 by gts455, on Flickr
IMG_0084 by gts455, on Flickr
2001 Honda RC51 SP1
1999 Aprilia RS50
gts455 is offline
Old 12-27-2014, 8:39 AM Thread Starter
Quoted: 13 Post(s)
IMG_0085 by gts455, on Flickr
IMG_0110 by gts455, on Flickr
IMG_0112 by gts455, on Flickr
IMG_0113 by gts455, on Flickr
2001 Honda RC51 SP1
1999 Aprilia RS50
gts455 is offline
Old 12-27-2014, 8:41 AM Thread Starter
Quoted: 13 Post(s)
IMG_0114 by gts455, on Flickr
IMG_0111 by gts455, on Flickr
IMG_0209 by gts455, on Flickr
IMG_0210 by gts455, on Flickr
2001 Honda RC51 SP1
1999 Aprilia RS50
gts455 is offline
Old 12-27-2014, 8:43 AM Thread Starter
Quoted: 13 Post(s)
BEFORE
AFTER
IMG_0413 by gts455, on Flickr
IMG_0412 by gts455, on Flickr
2001 Honda RC51 SP1
1999 Aprilia RS50
gts455 is offline
Old 12-27-2014, 8:46 AM Thread Starter
Quoted: 13 Post(s)
I finally "finished" it in August, a year after i started.
IMG_0429 by gts455, on Flickr
IMG_0425 by gts455, on Flickr
IMG_0437 by gts455, on Flickr
IMG_0441 by gts455, on Flickr
2001 Honda RC51 SP1
1999 Aprilia RS50
gts455 is offline
Old 12-27-2014, 8:50 AM Thread Starter
Quoted: 13 Post(s)
I rode the bike till this October when i took it apart again for another winter refresh and to address some things i had put off. New cush drive rubbers, Carb clean and rebuild, new grips, and Quick action throttle. Also a rear shock update.
IMG_1270 by gts455, on Flickr
IMG_1285 by gts455, on Flickr
I plan on dumping the coolant again to make sure it gets any last bit of residue out of the system, new oil, and another brake fluid flush before this spring.
2001 Honda RC51 SP1
1999 Aprilia RS50
gts455 is offline
xR's Build 900RR build thread xRenesis Honda FireBlade 17 07-29-2016 12:26 AM
cbr900rr project build fbladerider Introductions 3 12-30-2013 6:47 AM
900rr sc33 Dimi_RR Review My Ride 6 09-16-2013 12:18 PM
cbr900rr build adam1983 Streetfighter 0 08-01-2011 2:30 PM
sc33 carburetors SorinRS4 Honda FireBlade 10 09-10-2010 12:12 AM
