Clutch not disengaging? - Honda Motorcycles - FireBlades.org
post #1 of 4 Old 12-27-2014, 6:02 PM Thread Starter
I have a 2005 CBR1000RR (milage is around 25,000 km) and nothing happens after letting the clutch out while in gear. The bike will not move. Clutch lever has good resistance and the fluid was changed 3,500 km ago. Is this the clutch not disengaging?
keeksrc51 is offline
post #2 of 4 Old 12-27-2014, 7:01 PM
Quoted: 159 Post(s)
Reputation Power: 122
Re: Clutch not disengaging?
Have you tried any gears other than 1st? The clutch would not be engaging, if that were the problem. What led up to it, was any maintenance performed, has the bike been sitting? Any noises to go with it? Has it been slipping, or did it just stop engaging all at once? I've never heard of an oil causing a clutch to completely slip so bad the bike wouldn't move, but out of curiosity what oil are you/have you been running? If you put the bike in gear, engine off, and try to push it what happens?
fj1200rj is offline
post #3 of 4 Old 12-27-2014, 7:46 PM Thread Starter
Same thing in 2nd gear. Will try the others and see if any different. The bike has been sitting for about 6 weeks since it was last ridden. No noises with it or any slippage. Oil was changed 3,500 km ago, I use Motul 7100 full synthetic.
I'm embarrassed to say that a 1st gear burn out led up to it. Also, it got quite hot - during this moment of temporary insanity.
While on a paddock stand, in gear (any gear), engine off, I can turn the rear wheel by hand, with varying degrees of resistance depending what gear it's in.
post #4 of 4 Old 12-27-2014, 10:20 PM
Quoted: 159 Post(s)
You may have glazed the hell out of your friction plates.
fj1200rj is offline
Tags
clutch , disengage , problems
clutch not disengaging 00 929 JORDAN N General Discussion 12 07-06-2009 4:05 AM
PLEASE NEED HELP NOW..CLUTCH NOT DISENGAGING LITEITUP Honda FireBlade 7 06-01-2009 10:32 AM
Clutch not disengaging on 2001 CBR600 F1 bo.vestergaard Honda CBR 600 2 02-08-2009 9:48 PM
929 clutch not disengaging all the way pavetim Honda FireBlade 5 08-28-2008 6:20 PM
VFR clutch not disengaging! prorider17 Honda Interceptor / VFR 3 06-29-2008 5:04 PM
