900rr front mudguard - Honda Motorcycles - FireBlades.org
post #1 of 9 Old 01-04-2015, 3:57 PM Thread Starter
Hi all please could you help me. I am trying to remove a 900rr 96 front mudguard with rounded rusted bolt. Don't won't to damage the mudguard. Advise needed.
thanks carl.
Carlos8289 is offline
post #2 of 9 Old 01-05-2015, 4:16 PM
Reputation Power: 6
Re: 900rr front mudguard
I've just done a similar thing with a 98 mudguard. I achieved it with an angle grinder over several hours, to ensure it didn't go so hot as to melt the plastic.
Uebercyclette is offline
post #3 of 9 Old 01-05-2015, 4:27 PM Thread Starter
Thanks for your help. I didn't know which route to go down drill or grind it. Where did u start bolt heads or from the inside. It has custom paint so didn't want to damage it all. Thanks
post #4 of 9 Old 01-05-2015, 4:50 PM
Reputation Power: 6
The way I did it; by which I don't necessarily mean the best; was to grind back down so the head remained intact. I did it this way as it was less metal to grind than the head of the bolt.
post #5 of 9 Old 01-05-2015, 5:46 PM
Reputation Power: 8
thanks carl.
Yeah they're always a pain in the arse. I had that before now but i got mine out by hammering a slightly larger torx bit and holding the square nut on the inside with a spanner. But, depends on whether it's the top or bottom bolts that are stuck.
IIRC the top ones are held in by a plate that has nuts welded on to it n the bottom has a plastic u-piece that holds captivated square nuts?
cbrherms is offline
post #6 of 9 Old 01-06-2015, 9:54 AM
Reputation Power: 7
You can use a soldering iron (decent one), by placing the tip of it on the bolt head and heating up the metal to allow the bolt loosen the threads and try to get it out while its hot....here is an article that might help also:
Dan's Motorcycle Stripped & Stuck Bolts
Kevin
2001 Honda CBR 929rr Repsol Edition (Arielle)
https://www.fireblades.org/forums/hon...back-life.html
KGPrice is offline
post #7 of 9 Old 01-06-2015, 10:04 AM
Reputation Power: 8
I wouldn't have thought a soldering iron would conduct the heat quickly enough to be that effective?
cbrherms is offline
post #8 of 9 Old 01-06-2015, 10:25 AM
Reputation Power: 7
The soldering iron heats up at a decent rate and its easy to direct the heat to a point as it will heat up the whole bolt but should not do any damage to the fairing.
Kevin
KGPrice is offline
post #9 of 9 Old 01-06-2015, 12:47 PM Thread Starter
Thanks for all your advise. I went with the grinder to the back and a drilled the front. Worked a treat. Had to do in in stages tho so didn't melt the mudguard.
2012 front mudguard extender minman Honda FireBlade 2 06-23-2014 1:08 PM
front mudguard / fender stinkydog General Discussion 4 05-25-2014 8:28 PM
Carbon front mudguard/fender: what make? jtree03 Honda FireBlade 1 10-16-2009 5:27 PM
Carbon fibre front fender / mudguard and brake line brackets CBR1000RR8 mjpartyboy Honda FireBlade 0 09-12-2009 6:11 AM
Fr Mudguard LionBlade Honda CBR400RR 5 02-23-2009 7:28 AM
